Higher Education
last person joined: 21 days ago
Got questions on how to enable mobility in education? Submit them here!
Radius Certificate for ClearPass with VIP
  • 1.  Radius Certificate for ClearPass with VIP
    Posted Jul 07, 2015 04:07 PM
    Question regarding which hostanme should i register with CA.
    Example
    Server 1
    wifi1.wireless.com
    server 2
    wifi2.wireless.com
    VIP
    wifi.wireless.com = 137.52.x.x.
    Should i register the hostanme of each server so each server have it own private keys? Or would register the VIP hostname be enough?
    When wireless clients do EAP-PEAP would they be presented with the server certificate or the VIP?
    Thank you
    Nils
  • 2.  RE: Radius Certificate for ClearPass with VIP
    Posted Jul 07, 2015 04:11 PM
    You can do a single certificate with:
    CN = wifi.wireless.com
    SAN = DNS:wifi.wireless.com,DNS:wifi1.wireless.com,DNS:wifi2.wireless.com
    You can then import the certificate and key to both servers.
  • 3.  RE: Radius Certificate for ClearPass with VIP
    Posted Jul 07, 2015 04:22 PM
    Thank you!
  • 4.  RE: Radius Certificate for ClearPass with VIP
    Posted Jul 08, 2015 10:21 AM
    subject alternative name field?
  • 5.  RE: Radius Certificate for ClearPass with VIP
    Posted Jul 08, 2015 10:22 AM
    You can't include a private IP in a public certificate anymore.
  • 6.  RE: Radius Certificate for ClearPass with VIP
    Posted Jul 08, 2015 10:27 AM
    When i am trying to generate the request. I am receiving the following message:
    Subject Alternate Name must start with either email, URI, DNS, RID or IP, followed by a : (e.g., IP:192.168.1.2)
    When using the format:
    CN: clearpass.nova.edu
    SAN: dns=clearpass.nova.edu&dns=clearpass1.nu.nova.edu&dns=clearpass.nu.nova.edu
  • 7.  RE: Radius Certificate for ClearPass with VIP
    Posted Jul 08, 2015 10:30 AM
    It should be DNS: (DNS colon, not equals) and then commas after each entry.
  • 8.  RE: Radius Certificate for ClearPass with VIP
    Posted Jul 08, 2015 02:47 PM
    It doesnt work with dns formart:
    dns:clearpass.nova.edu,dns:clearpass1.nunet.nova.edu,dns:clearpass.nunet.nova.edu
    But works with the IP format:
    IP:137.52.x.x,IP:137.52.x.x,IP:137.52.x.x
    Any ideas for the dns format?
  • 9.  RE: Radius Certificate for ClearPass with VIP
    MVP
    Posted Jul 08, 2015 02:50 PM
    DNS:
    not dns:
    Case matters.
  • 10.  RE: Radius Certificate for ClearPass with VIP
    Posted Jul 08, 2015 03:01 PM
    That's right!
    It worked. Thank you!!
  • 11.  RE: Radius Certificate for ClearPass with VIP
    Posted Dec 03, 2015 09:54 AM
    Hi all,
    i will be very grateful for the help.
    I also have two servers clearpass: ip1: 10.0.0.1, ip2:10.0.02, ip-VIP:10.0.0.3
    In the controller i set radius server IP: 10.0.0.3
    what should point out  in radius certeficate fields CN and SAN ?
    Can  i simply set CN 10.0.0.3 and use same certificate in both CleaPass servers?
    I need to have successfully connected win7-8 devices with enabled "verify server certificate" option by default.
  • 12.  RE: Radius Certificate for ClearPass with VIP
    Posted Dec 03, 2015 09:56 AM
    The common name and first SAN entry should be the DNS Name of the VIP.
    The second and third SAN entry should be the individual server DNS names.
  • 13.  RE: Radius Certificate for ClearPass with VIP
    Posted Dec 03, 2015 10:07 AM
    But in this situation, how clients will find that provided certificate really belongs to this radius server?
    After all, neither the controller nor the customers do not know the FQDN of radius server.
    Or clients do not make such check?
    Now I have installed the certificate with these fields:
    CN  clearpass-cluster
    SAN   IP:10.0.0.1,IP:10.0.0.2,IP:10.0.0.3,DNS:name1.org,DNS:name2.org,DNS:cluster-name.org
    And win7-8 clients can't connect until you remove the option "Validate server certificate".
  • 14.  RE: Radius Certificate for ClearPass with VIP
    Posted Dec 03, 2015 10:12 AM
    User's will generally recognize the domain name and click accept. Your other
    options are using QuickConnect to configure the clients, group
    policy/profile manager if the devices are in your control, or Onboarding.
    The client needs to configured to the trust the CN and issuing CA of the
    certificate.
