last person joined: 8 hours ago
Radius CoA Bounce Host-Port Failed
  • 1.  Radius CoA Bounce Host-Port Failed
    Posted May 06, 2017 12:26 AM
    Hi all,
    I'm having an issue with Radius CoA, which doesn't work as I expected. What I'm trying to do is to use CPPM to authenticate a device based on its MAC address, then profile it and after that have CPPM send bounce host-port message to the switch to assign proper VLAN for that device. The authentication and profiling process have worked well so far. However, I got stuck at CoA step:
    I'm using an Aruba 5400 switch for testing. I tried changing the CoA profile to Aruba Bounce Host-Port (instead of HPE Bounce Host-Port), but it didn't work either:
    I checked the switch and look like it did receive CoA messages from CPPM:
    Below is my configuration on CPPM and Aruba switch:
    Please tell me what I did wrong. I really appreciate your help.
    Thank you,
