Radius CoA Bounce Host-Port Failed
This thread has been viewed 16 times
  • 1.  Radius CoA Bounce Host-Port Failed
    Posted May 07, 2017 01:36 AM
    Hi all,
    I'm having an issue with Radius CoA, which doesn't work as I expected. What I'm trying to do is to use CPPM to authenticate a device based on its MAC address, then profile it and after that have CPPM send bounce host-port message to the switch to assign proper VLAN for that device. The authentication and profiling process have worked well so far. However, I got stuck at CoA step:
    I'm using an Aruba 5400 switch for testing. I tried changing the CoA profile to Aruba Bounce Host-Port (instead of HPE Bounce Host-Port), but it didn't work either:
    I checked the switch and look like it did receive CoA messages from CPPM:
    Below is my configuration on CPPM and Aruba switch:
    Please tell me what I did wrong. I really appreciate your help.
    Thank you,
  • 2.  RE: Radius CoA Bounce Host-Port Failed
    Posted May 08, 2017 11:38 PM
    Can anyone share your ideas on this? Where should I check next to make it work?
    Thank you,
  • 3.  RE: Radius CoA Bounce Host-Port Failed
    Posted May 09, 2017 06:23 AM
    What message do you get when try it manually from Access Tracker?
  • 4.  RE: Radius CoA Bounce Host-Port Failed
    Posted May 09, 2017 11:49 PM
    Hi cappali,
    I got ACCEPT message from Radius server but the Radius CoA tab showed that bounce host-port had failed.
  • 5.  RE: Radius CoA Bounce Host-Port Failed
    Posted May 09, 2017 11:54 PM
    Are both the switch and ClearPass server using NTP?
  • 6.  RE: Radius CoA Bounce Host-Port Failed
    Posted May 21, 2019 09:52 AM
    Thanks Tim, that worked for me.
    kudos :)
