generally you need to enable the Huawei RADIUS dictionary. Administration » Dictionaries » RADIUS
then based on the RADIUS attributes for the vendor, you'll have corresponding RADIUS dynamic authz temp
I could not find anything for Hauwei, which means that you need to find out the RADIUS attribute for Hauwei that does the port bounce.
then get that added to the RADIUS dictionary. Once you have that, you can build the "RADIUS dynamic authz temp"
as an example, here is the H3C CoA template.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/9a09d67f01144de49603487d351dfcc6.png)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/8956c604e7324798944df7f4736376f7.png)
Original Message:
Sent: Dec 26, 2022 07:48 AM
Subject: Radius CoA for Huawei Switches
Dear Experts,
Can someone guide me how to write the Radius CoA (Bounce port) profile for Huawei switches?
owais
