Radius COA problem between controller and clearpass
This thread has been viewed 23 times
  • 1.  Radius COA problem between controller and clearpass
    Posted Dec 30, 2014 05:35 AM
    I want to use Radius CoA between a controler and Clearpass for disconnect user session with a "Terminate Aruba Session" but it doesn't work.
    I have this messge in "acccess tracker"
    Status MessageSession-Context-Not-Found
    In the controler,
    in the RFC Statistics,  all the time the "Disconnect Rej" increment  !!!
    in the log of aaa about RFC, i have the message  :
    Dec 30 10:36:28 :121031: <DBUG> |authmgr| |aaa| [rc_api.c:1188] Invalid parameters, setting nas_port_type to wireless
    Dec 30 10:36:29 :121031: <DBUG> |authmgr| |aaa| [rc_sequence.c:115] seq_num_timeout_handler: Freed 0 entries
    Do you have an idea ?
    My configuration :
    CPPM: RADIUS CoA is enabled and using port 3799.
    Controller: RFC3746 server defined in AAA profile. Key matches key specific in device details above.
    Regards
    Yann
  • 2.  RE: Radius COA problem between controller and clearpass
    Posted Dec 30, 2014 06:16 AM
    Yann Dorval,
    Please make sure that the nas-ip-address parameter configured on the controller for clearpass matches the ip address defined in ClearPass
  • 3.  RE: Radius COA problem between controller and clearpass
    Posted Dec 30, 2014 06:30 AM
    Hi Cjoseph,
    Thanks for your answer :
    i have check it
    On my controler :
    On my CPPM
    regards
  • 4.  RE: Radius COA problem between controller and clearpass
    Posted Dec 30, 2014 06:32 AM
    Yann Dorval,
    Not in the RFC 3576 definition.  Check in the Radius Server definition on the controller.
  • 5.  RE: Radius COA problem between controller and clearpass
    Posted Dec 30, 2014 07:36 AM
    Cjoseph,
    I think it's good
    Regards
    Yann
  • 6.  RE: Radius COA problem between controller and clearpass
    Posted Dec 30, 2014 10:28 AM
    It's strange because in my Access Tracker -> Accounting -> Networ Detail, i have the good NAS-Port-Type
    NAS IP Address:
    10.1.8.50:0
    NAS Port Type:
    Wireless-802.11
    regards
    Yann
  • 7.  RE: Radius COA problem between controller and clearpass
    Posted Dec 30, 2014 11:08 AM
    in debug aaa you can see, 2 msg about the NAS port Type
  • 8.  RE: Radius COA problem between controller and clearpass
    Posted Dec 30, 2014 12:52 PM
    i don't see the COA server connected to your AAA profile, is it there?
    your not doing anything special with your network, i.e. NATing, firewall in between, ...?
  • 9.  RE: Radius COA problem between controller and clearpass
    Posted Dec 31, 2014 03:39 AM
    hi boneyard,
    thanks for your reply, for me it's already connected to my aaa profile, see below ( RFC 3576 server 10.1.8.7).
    The CPPM and Clearpass are in the same VLAN, network, IP range,  there are nothing between each.
    Regards
    Yann
  • 10.  RE: Radius COA problem between controller and clearpass
    Posted Dec 31, 2014 05:45 AM
    and you can't do an CoA on any session? you have check with a recent session you just logged in with?
    only thing i would try then is to reset all shared secrets, so on controller (RFC... and radius server) and on clearpass with an easy one. just to rule out any copy paste / fat finger errors.
    after that i would contact TAC (and go through all of the above again first :) ).
  • 11.  RE: Radius COA problem between controller and clearpass
    Posted Dec 31, 2014 05:55 AM
    I just changed all the passwords, test with another enforcement policy and profile, with another controler, with another service etc ...., i think i have tested all that i could :)
    Yesterday i have opened a case, i'm in waiting to reply from them.
    Thanks for your help, Happy Holidays
    Regards
    Yann
  • 12.  RE: Radius COA problem between controller and clearpass
    Posted Dec 31, 2014 06:47 AM
    For your information, my AP is in RAP Mode and the VAP is in Bridge mode
    I just configure my VAP in tunnel mode and  the CoA works good now !
    My question : is there  a prerequisite of works for CoA in bridge mode ?
    regards
    Yann
  • 13.  RE: Radius COA problem between controller and clearpass
    Posted Jan 02, 2015 07:03 AM
    thanks for reporting back about your finding. sounds like a possible reason for it not working. tried to find a source saying this is indeed the issue, but can't find one. hopefully your ticket with TAC will give  a definite answer. be sure to relay that.
  • 14.  RE: Radius COA problem between controller and clearpass
    Posted Jan 06, 2015 09:27 AM
    I confirm, with one CAP on the VAP in tunnel mode,it's works well, but when i configure the VAP in bridge mode, i have the message "Session-Context-Not-Found"
  • 15.  RE: Radius COA problem between controller and clearpass
    Posted Jan 06, 2015 02:32 PM
    what is TAC saying about this, is there no way to pull this off with a bridged SSID?
  • 16.  RE: Radius COA problem between controller and clearpass
    Posted Jan 07, 2015 01:02 PM
    Hi Boneyard,
    yes, they answered me ... "CoA will not be supported in the bridge mode", it's a big problem for my project ...
    Thanks you for your help
  • 17.  RE: Radius COA problem between controller and clearpass
    Posted Jan 02, 2015 07:36 AM
    Yann Dorval,
    What version of ArubaOS are you using?
    Are you sending radius accounting information to clearpass?
  • 18.  RE: Radius COA problem between controller and clearpass
    Posted Jan 05, 2015 04:12 AM
    Hi Cjoseph,
    The Version 6.4.2.2 is install on controller.
    Yes, i send the radius accounting information from the controller to clearpass.
    Regards
    Yann
