Radius CoA with Instant
  • 1.  Radius CoA with Instant
    Posted Jun 19, 2018 07:07 AM
    I want to change user role of a client with Radius CoA, however I can't get it work. How can I troubleshoot CoA on Instant? coa-request to instant VC is captured via wireshark.
    First client gets a role "Role1" by Radius radreply attribute Filter-Id, this works. Using radclient to disconnect clients works too and clients reauthenticate immediately which is expect behavior.
    I can verfiy this on Virtual Controller by "show derivation-rules"
    show derivation-rulesshow derivation-rules
    Now the problem,
    send a coa request and receive CoA-ACK, ok
    I don't know why there is a immediate Access-Challenge after sending coa request. Can I troubleshoot on VC why it doesnt update client user role to "Role2" and why client initiate a Access-Challange on Instant VC.
    Role2 is created on VC and RFC3576 is enabled for auth-server
    Attachment(s)
    txt
    instant_VC.cfg.txt   3 KB 1 version
  • 2.  RE: Radius CoA with Instant
    Posted Jun 19, 2018 07:14 AM
    You should not be using derivation rules. Return the first role using the Aruba-User-Role VSA.
    Remove all derivation rules and try again.
  • 3.  RE: Radius CoA with Instant
    Posted Jun 19, 2018 07:44 AM
    I removed the Role assignments for ssid-profile
    and also i changed radreply attribute Filter-Id to Aruba-User-Role
    Still the same result. I think the immediate Access-Challenge overwrites the coa-request on instant VC, is there a way to verify this on the VC log?
    On VC Support Command: AP Log ALL, I can see that VC handle the stm_rfc3576_request and executes handle_disconnect_user. Does this explain the immediate Access-Challenge after the coa-request?
    Jun 19 11:27:08  stm[3694]: stm: rfc3576 req 0 for a0:8d:16:9d:fb:2f:172.31.98.122 (role=) from:10.0.99.24
    Jun 19 11:27:08  stm[3694]: stm stm_rfc3576_request, 230: wired flag for client a0:8d:16:9d:fb:2f is 0
    Jun 19 11:27:08  stm[3694]: handle_disconnect_user: 10659: sci->mac_authenticate=0 sci->captive_portal=0 sta->dot1xctx=0x1fe33c
    see log file attached.
    Please let me know if you need further log.
    regards,
    Peter
    Attachment(s)
    txt
    command_AP_Log_All.txt   9 KB 1 version
  • 4.  RE: Radius CoA with Instant
    Posted Jun 19, 2018 07:46 AM
    What is your RADIUS server?
  • 5.  RE: Radius CoA with Instant
    Posted Jun 19, 2018 07:56 AM
    I'm using freeradius 3.0.16 on ubuntu and have the aruba VSA for freeradius placed in /usr/share/freeradius
    I read the post:
    What attribute do I use when configuring an RFC3576 server for change of authorization?
    by aruba emplyoee aarunkumar
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/What-attribute-do-I-use-when-configuring-an-RFC3576-server-for/ta-p/183484
    I assume this can work on Instant.
  • 6.  RE: Radius CoA with Instant
    Posted Jun 19, 2018 07:58 AM
    Change User Role uses filter-id for the role name. But do not configure an SDR.
