last person joined: 8 hours ago
RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
  • 1.  RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
    Posted Aug 25, 2016 05:38 PM
    Hi all,
    I had expring RADIUS certs on a Clearpass server that needed replacing.  Upon placing the new CA signed certs (CA cert is on endpoint and selected in wireless profile for server validation) the access tracker started showing reject entries with error code 215.  The alert for the request showed.
    I suspect this is happening because client sessions are already established using the old cert.  But I was not seeing any new accept entries coming through (perhaps no new sessions were being attempted due to the late night change window) so was worried that new clients could not associate.
    How can I have the already associated endpoints restart their EAP session so that they get the new certs?  Do I need to disassociate all of the users forcefully to make this happen or will it happen after a given period?
    Thanks.  :)
    Nathan.
  • 2.  RE: RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
    Posted Aug 25, 2016 05:50 PM
    Is your RADIUS cert public or privately signed?
  • 3.  RE: RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
    Posted Aug 25, 2016 06:00 PM
    It is privatly signed by the AD CA, but it is the same CA cert that signed the first one (they dont expire for 10 years but the IA cert's expire after 2).
    So we know the client is happy with the cert because it is signed with the same root as the original one.
  • 4.  RE: RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
    Posted Aug 25, 2016 06:01 PM
    Did you chain the cert prior to import?
  • 5.  RE: RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
    Posted Aug 25, 2016 06:09 PM
    The public and private key imported without errors, and it does show the root ca right below the radius cert.
    Looks like this.
    Certificate:
        Data:
            Version: 3 (0x2)
            Serial Number: 1713 (0x6b1)
        Signature Algorithm: sha256WithRSAEncryption
            Issuer: <REDACTED>
            Validity
                Not Before: Jun  1 05:06:36 2016 GMT
                Not After : Jun  2 05:06:36 2018 GMT
            Subject: <REDACTED>
            Subject Public Key Info:
                Public Key Algorithm: rsaEncryption
                    Public-Key: (2048 bit)
                    Modulus:
                        <REDACTED>
                    Exponent: 65537 (0x10001)
            X509v3 extensions:
                X509v3 Basic Constraints:
                    CA:FALSE
                X509v3 Key Usage:
                    Digital Signature, Key Encipherment, Data Encipherment, Key Agreement
                X509v3 Extended Key Usage:
                    TLS Web Server Authentication, TLS Web Client Authentication, Code Signing
                X509v3 Subject Key Identifier: <REDACTED>:88:6D:68
                X509v3 Authority Key Identifier:
                    keyid:<REDACTED>:05:BB:0C
                    DirName:<REDACTED> Certification Authority Serial 5/emailAddress=<REDACTED>
                X509v3 Subject Alternative Name:
                    <REDACTED>
             <REDACTED>
    And root looks like this:
    Certificate Details
    Certificate:
        Data:
            Version: 3 (0x2)
            Serial Number: 5 (0x5)
        Signature Algorithm: sha1WithRSAEncryption
            Issuer: <REDACTED>
            Validity
                Not Before: May 15 03:46:17 2013 GMT
                Not After : May 15 03:46:17 2023 GMT
            Subject: <REDACTED>
                    Modulus:
                        <REDACTED>
            X509v3 extensions:
                X509v3 Subject Key Identifier: <REDACTED>:05:BB:0C
                    keyid: <REDACTED>05:BB:0C
                    DirName:<REDACTED>
                    CA:TRUE
             <REDACTED>
  • 6.  RE: RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
    Posted Aug 25, 2016 06:11 PM
    But did you chain the public key before importing it?
  • 7.  RE: RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
    Posted Aug 25, 2016 06:25 PM
    Would I need to do that if it was signed by the same root as the cert I am replacing?
    I did not do it because it was the same.  Would this error happen if it was not chained to the public key before importing?
  • 8.  RE: RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
    Posted Aug 25, 2016 06:31 PM
    Yes. Simply take your public key and open it in a plain text editor. Take the PEM encoded CA cert and add it after the RADIUS cert. Save and then reimport.
  • 9.  RE: RADIUS EAP-PEAP: fatal alert by client - access_denied TLS session reuse error when replacing certs.
    Posted Aug 25, 2016 06:34 PM
    Ok.  Chained the root to it and reimported the certs again.  But still getting same 215 reject.
