Radius failed for client . Resources-Unavailable.
  • 1.  Radius failed for client . Resources-Unavailable.
    Posted Apr 06, 2021 07:45 PM
    I am having issues with getting clearpass to switch vlan assignments on a Cisco 3650 switch. I can run manual CoA change status in access tracker but I cannot use a enforcement profile to change the vlan from a restricted vlan to a all access vlan based on successful health posture. My initial radius service works fine and assigns users to restricted vlan 203 if the health posture does not equal HEALTHY:
    But for some reason my WEBAUTH service enforcement policy will not send the CoA to switch the vlan to all access vlan 196:
    When I check access tracker I cannot send the CoA using this profile:
    But I can send some of the dynamic auth CoA profiles:
    abraham
  • 2.  RE: Radius failed for client . Resources-Unavailable.
    Posted Apr 07, 2021 03:07 AM
    you should enable use cached role and posture check box
    Alper
  • 3.  RE: Radius failed for client . Resources-Unavailable.
    Posted Apr 08, 2021 11:13 AM
    Thanks a bunch! That worked like a charm. Thanks for your help.
    abraham
