Radius Interim Accounting
  • 1.  Radius Interim Accounting
    Posted Jun 14, 2017 05:15 AM
    we want to integrate our ParloAlto Firewall with clearpass an our Instant Cluster.
    The Aruba integration Paper describes only the Controller szenario.
    where can I find the radius interim accounting on an Aruba Instant?
  • 2.  RE: Radius Interim Accounting
  • 3.  RE: Radius Interim Accounting
    Posted Jun 22, 2017 03:29 PM
    I couldn't find anything in the SSID-Profile.  I think with an IAP you are supposed to do it locally on the IAP instead of through ClearPass.  This is the guide I used:
    http://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/RTLS_conf/panFirewallInt.htm
