RADIUS Load Balancing - Kinda'
  • 1.  RADIUS Load Balancing - Kinda'
    Posted Sep 11, 2013 03:09 PM
    I'm a long time listener, but first time caller.
    Many wireless products list RADIUS servers in a primary/back-up arrangement where the primary is used whenever available, and the back-up is only used when the primary is unavailable.  Aruba uses server groups, with no explicit primary/back-up relationship.  That said, it appears that the controllers use the first server in the list and only moves down the list if the ones above it are unavailable - an implied primary/back-up arrangement..
    Is there any way to get the controllers to spread auth around the server group instead of sending everything to the first server in the list?
    Chuck Enfield
    Manager, Wireless Systems & Engineering
    Penn State
  • 2.  RE: RADIUS Load Balancing - Kinda'
    Posted Sep 11, 2013 03:15 PM
    Load balancing AAA servers is on the roadmap. I can't say exactly when it will show up, but it is something they are going to do. You're local SE can probably give you more details.
  • 3.  RE: RADIUS Load Balancing - Kinda'
    Posted Mar 09, 2014 11:05 AM
    is this the virtual IP that got added in 6.3 or is there more to expect?
  • 4.  RE: RADIUS Load Balancing - Kinda'
    Posted Sep 11, 2013 10:29 PM
    You can always use a loadbalancer
  • 5.  RE: RADIUS Load Balancing - Kinda'
    Posted Sep 11, 2013 11:40 PM
    What RADIUS server are you using?   You could consider setting up a RADIUS Proxy and distributes authentications to other servers.     In your server group, you could define the Proxy as #1 and your physical servers as #2 and #3 in the event the Proxy is down.
    I've set this up using NPS in the past.
  • 6.  RE: RADIUS Load Balancing - Kinda'
    Posted Sep 12, 2013 08:45 AM
    Thanks.  We're familiar with things we can do to the server infrastructure.  I was hoping there was a quick change we could make on the controllers to mitigate a problem we're having until the servers can be properly dealt with.
    Chuck
  • 7.  RE: RADIUS Load Balancing - Kinda'
    MVP
    Posted Mar 09, 2014 12:41 PM
    Probably the best thing you can do is create 2 server-groups (containing the same servers in inverse order)  and apply those 2 server-groups to different ap-groups.
    This offcourse is far from perfect but you should be able to divide the load alot better.
  • 8.  RE: RADIUS Load Balancing - Kinda'
