Comware
Β View Only
radius peap-mschapv2 - User 'unknown'
This thread has been viewed 31 times
  • 1.  radius peap-mschapv2 - User 'unknown'
    Posted Feb 02, 2023 09:24 AM
    Hello All,
    I've configured Radius authentication on Aruba 2930M with ms-chapv2 encryption:
    aaa server-group radius "NPS" host 192.168.100.101
    aaa server-group radius "NPS" host 192.168.100.102
    aaa authentication login privilege-mode
    aaa authentication web login peap-mschapv2 server-group "NPS" local
    aaa authentication web enable peap-mschapv2 server-group "NPS" local
    aaa authentication ssh login radius local
    aaa authentication ssh enable radius local​
    On the NPS Server I see that authentication was successful:
    but on the switch I see an error and can't login in the web-console:
    W 02/02/23 13:32:09 00419 auth: Invalid user name/password on WEB-UI session
                User 'unknown' is trying to login from 192.168.200.125
    ----  Bottom of Log : Events Listed = 497  ----​
    what is wrong? With PAP encryption everything works.
    When I enable ms-chapv2 for ssh, then I see the username, but switch says invalid credentials:
    W 02/02/23 13:53:26 00419 auth: Invalid user name/password on SSH session User
    'my-user' is trying to login from 192.168.200.125
    ---- Bottom of Log : Events Listed = 502 ----​
    Thank you in advance!
  • 2.  RE: radius peap-mschapv2 - User 'unknown'
    Posted Feb 02, 2023 12:05 PM
    this may be due to a certificate issue:
    How can I upload AD Root CA? The switch always tries to replace Default CA:
    I found I can do it via CLI, but a command not available:
    sw-014(config)# crypto pki ta-profile domain-root
    sw-014(config)# ta-certificate import terminal
    Invalid input: ta-certificate
    sw-014(config)#​
  • 3.  RE: radius peap-mschapv2 - User 'unknown'
    Posted Feb 03, 2023 02:32 AM
    Is the NPS configured to return the RADIUS attribute service-type with a value of 6?
    This should be configured when you are using the option " aaa authentication login privilege-mode"
    https://techhub.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8152_wb_2920_asg/content/ch06s04.html
    If you dont have access to the NPS config maybe you can check by removing " aaa authentication login privilege-mode"
  • 4.  RE: radius peap-mschapv2 - User 'unknown'
    Posted Feb 03, 2023 05:39 AM
    Thanks a lot! I have access to the NPS, now I need to find to adjust it 😊
    without "aaa authentication login privilege-mode" it works πŸ‘
  • 5.  RE: radius peap-mschapv2 - User 'unknown'
    Posted Feb 03, 2023 11:02 AM
    I've found this. I hope it can be useful for others:
