  • 1.  Radius Proxy
    Posted May 24, 2015 09:33 AM
    dear all,
    i found in Instant AP the item , Radius proxy, i have enderstand that is used  to proxy from different AP, so that  they will be sent  from the Virtual controlleur (with the cluster Address)
    i have two question:
    1. is it true ?!
    2. is it the best practice to use this method instead of the standard method  (configure each AP as a radius client ?:
    Regards
  • 2.  RE: Radius Proxy
    Posted May 24, 2015 09:36 AM
    Dynamic Radius Proxy is a best practice. Some radius servers have a limit to the number of radius clients that can be configured. Having Dynamic radius proxy reduces administration.
  • 3.  RE: Radius Proxy
    Posted May 24, 2015 09:37 AM
    Correct. It prevents you from having to add each AP as a RADIUS client.
    Tim
  • 4.  RE: Radius Proxy
    Posted May 24, 2015 10:36 AM
    thank's for the help.
  • 5.  RE: Radius Proxy
    Posted May 25, 2015 08:08 AM
    Hello
    1. it is true, all Radius requests were sent by the virtual controller address
    2. it is a question of the configuration overhead (AP and Radius Server) and the functional safety with regard to bugs or something
    I would use the Radius Proxy to avoid configuration mistakes and a single point of configuration
    Regards
