If I have a master/local setup (all APs are terminated at local), does the radius request come from master's IP or local's IP? The reason I am asking this because even though I don't have the master's IP listed under Network > Devices, when I do "AAA Test Server" from the local, I see the master's IP in the logs.
The request will be coming from the local controller.
Make sure that you configure the Radius source IP address or NAS IP to be local controller IP address
This configuration is done at the local controller side of things.
Thank you for your quick response.
