RADIUS source interface - ArubaOS 6.2.1.2
  • 1.  RADIUS source interface - ArubaOS 6.2.1.2
    Posted Jun 13, 2013 04:26 AM
    Having recently deployed ArubaOS 6.2.1.2 on 2 x Aruba 7240 controllers I noticed some strange behaviour with the "ip radius source-interface" command. When this command is specified on the controllers (a master and a local with different vlan interfaces) everything works without issue.
    However, if either controller is reloaded this command seems to be cleared from the configuration and the controller reverts back to using the interface determined by routing. Has anybody else come across this problem?
    The same appears to happen if you specify the NAS IP address on each controller.
    David
    #7240
  • 2.  RE: RADIUS source interface - ArubaOS 6.2.1.2
    Posted Jun 18, 2013 06:03 AM
    UPDATE: This has been logged with Aruba TAC and replicated and is currently with engineering.
  • 3.  RE: RADIUS source interface - ArubaOS 6.2.1.2
    Posted Jul 02, 2013 05:10 AM
    what happened with this, defect ID?
  • 4.  RE: RADIUS source interface - ArubaOS 6.2.1.2
    Posted Jul 02, 2013 10:28 AM
    This was logged as bug id 85623 and is being fixed in the next release of 6.2 (6.2.1.3 I believe).
    David
