RADIUS Timeout on some IAPs
  • 1.  RADIUS Timeout on some IAPs
    Posted Apr 02, 2019 12:51 AM
    We are getting a high amount of RADIUS Timeouts, but not on all IAPs(?!)
    Authentication is through CLEARPASS
    Test device is a Surface running Windows 10
    When connecting to AP1 (which is a VC) - the authentication request in Airwave is ACCEPT
    Authentication Method: EAP-PEAP,EAP-MSCHAPv2
    Authentication Source: AD:dc1.our.domain.com
    When connecting to AP2 - autentication request in Airwave is TIMEOUT
    Authentication Source: None
    Error Code: 9002
    RADIUS Client did not complete EAP transaction
    APs are the same model - Aruba AP 325
    Firmware/image is the same
    VLANs on respective switches are the same
    Dynamic Proxy is enabled for RADIUS and TACACS
    Other posts regarding this error seem to indicate a certificate issue, however this connection works fine on one AP and not another - so I think we can safely assume the certificate is valid.
  • 2.  RE: RADIUS Timeout on some IAPs
    Posted Apr 02, 2019 03:37 AM
    With regards to the 9002, that often happens when you have recently changed the radius server certificate and a human is not there to click on "accept" to the new cert on some clients.  It might not be your situation, but it is one of the situations.
  • 3.  RE: RADIUS Timeout on some IAPs
    Posted Apr 09, 2019 10:09 PM
    Thanks for the response, but it doesn't appear to be the case in this instance.
  • 4.  RE: RADIUS Timeout on some IAPs
    Posted Apr 10, 2019 08:39 AM
    How many ClearPass servers are there in your environment? Just one, or are there others?
  • 5.  RE: RADIUS Timeout on some IAPs
    Posted Apr 10, 2019 06:43 PM
    We have one ClearPass server and domain controller (NPS) as the secondary authentication server.
  • 6.  RE: RADIUS Timeout on some IAPs
    Posted Apr 12, 2019 10:25 AM
    Is the same Radius certificate installed on both servers (ClearPass and NPS)?
  • 7.  RE: RADIUS Timeout on some IAPs
    Posted Apr 14, 2019 10:02 PM
    No the certificates are different
  • 8.  RE: RADIUS Timeout on some IAPs
    Posted Apr 15, 2019 03:34 AM
    Please make sure that the client is accepting both certificates.
    Preferably you should use the same authentication backend and certificates for your primary and secondary authentication server.
    Like already mentioned it looks like the client isn't accepting the server side certificate.
  • 9.  RE: RADIUS Timeout on some IAPs
    Posted Apr 15, 2019 07:08 PM
    The Root CA Certificate is the same on Airwave and the DC. The RADIUS/EAP Server Certificate was issued by our DC.
  • 10.  RE: RADIUS Timeout on some IAPs
    Posted Mar 18, 2020 01:03 PM
    Did you ever find a solution for this?
