Radsec client Certificate can't upload
This thread has been viewed 28 times
  • 1.  Radsec client Certificate can't upload
    Posted Apr 23, 2024 09:20 AM
    I am currently configuring an Aruba 6000 switch for a Radsec connection. I'm trying to upload my certificate generated by SCEPman for client authentication, and I keep getting this error:
    Moreover, it remains in its "csr_pending" state.
    Do you have any ideas?
    Thank you in advance.
  • 2.  RE: Radsec client Certificate can't upload
    Posted Apr 24, 2024 01:52 AM
    I generally use  inbuilt device certificate of CX switches for Radsec.
  • 3.  RE: Radsec client Certificate can't upload
    Posted Apr 24, 2024 03:44 AM
    Thanks for your response, if I use inbuilt device certificate how it will be able to be authenticated for Radsec connection ?
    Because the certification authority will not recognize this certificate.
  • 4.  RE: Radsec client Certificate can't upload
    Posted Apr 24, 2024 04:34 AM
    check this short guide for "Radsec and Aruba ClearPass – Part2"
    but basically on the switch you configure it to use its device certificate for radsec and then import the CA certificate that signed ClearPass's  radsec cert. (assuming you are using ClearPass at the other end of radsec. Also note that ClearPass already has the CA certificate that signed the device cert for switches and APs, all you have to do is enable it.
  • 5.  RE: Radsec client Certificate can't upload
    Posted Apr 24, 2024 04:44 AM
    Okay, thank you, I understand why. The problem is that I'm not using Clearpass at the other end of Radsec. Is there a specific way or format to upload a certificate to the switch?
  • 6.  RE: Radsec client Certificate can't upload
    Posted Apr 24, 2024 04:50 AM
    you can refer to the PKI section of the security guide for CX6000 switches.
  • 7.  RE: Radsec client Certificate can't upload
    Posted Apr 30, 2024 06:31 AM
    I followed the prerequisites for the certificate to be imported in the documentation you provided, but unfortunately, I still get the same error; it does not accept the certificate at all.
    Do you have any ideas, because I admit I'm running out of them ^^
  • 8.  RE: Radsec client Certificate can't upload
    Posted May 02, 2024 08:37 AM
    It's probably something in the certificate, which is hard to pinpoint without having access to it. The switch logs may provide some additional information.
    If you follow the documentation, it's expected to work. Your Aruba partner or TAC may be able to assist you in analyzing the certifcate or checking the switch logs.
  • 9.  RE: Radsec client Certificate can't upload
    Posted May 03, 2024 07:59 AM
    As per the error message, there is something wrong with the format of the private key you want to import.
    You can try import cert via cli. It need to be in PEM format.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
