Raidus CoA not working
This thread has been viewed 42 times
  • 1.  Raidus CoA not working
    Posted May 27, 2018 02:43 PM
    I'm working though some training labs from a Clearpass class I took last year. I setup a captive portal guest between my controller and CPPM everything works great, but I can't get the CoA to work. When I open the access tracker and change status it won't terminate the user. When I go look at the logs on the controller which I setup debug process Authmgr I get this May 27 10:29:38 :121006:  <3810> <WARN> |authmgr| |aaa| RADIUS (RFC 3576): Ignoring request from unknown client 10.20.20.200. I have verifed the RFC 3576 server shared key is correct matches my radius server configuration. Is there another setting on the controller that I need to set I can't find it anything.
    Other then the CoA everything else with reagard to radius works fine I have already done some 802.1x labs no issues.
  • 2.  RE: Raidus CoA not working
    MVP EXPERT
    Posted May 27, 2018 03:30 PM
    Some questions:
    • What is your Clearpass version 6.7.x or 6.6.x ?
    • What is your 3810 switch firmware ?
    CPPM > Configuration > Network > Devices
    Be sure you use the correct Vendor Name in your NAD configuration.
    I make the mistake before that the Vendor Name isnt Aruba but HP Enterprise.
    On your switch configuration be sure that you configured this:
    radius-server host "ip-clearpass" dyn-authorization
    Iam not 100% sure but i think it was firmware release 16.04 is needed to do this.
  • 3.  RE: Raidus CoA not working
    Posted May 27, 2018 03:59 PM
    CPPM version 6.6  Aruba 7005 wireless controller is the NAD. Test device is a ipad & win 7. Connecting using service guest local guest user account. Also tested it with 802.1x local user account both connect fine but when I try to change the CoA change status It says NAD does not respond. The controller log I posted above says it doesn't seem to reconize the server eventhough it authenticated with it.
  • 4.  RE: Raidus CoA not working
    Posted May 27, 2018 04:17 PM
    Do you have a RFC 3576 profile added to the proper AAA profile?
  • 5.  RE: Raidus CoA not working
    MVP EXPERT
    Posted May 27, 2018 04:19 PM
    Can you upload some screenshots of your AAA profile and Server Group?
  • 6.  RE: Raidus CoA not working
    MVP EXPERT
    Posted May 27, 2018 04:43 PM
    Does this help you?
    Schermafbeelding 2018-05-27 om 22.41.17.pngSchermafbeelding 2018-05-27 om 22.41.24.png
  • 7.  RE: Raidus CoA not working
    Posted May 27, 2018 07:16 PM
    Here is some of the controller config  Thanks for the pictures I usualy use CLI as you can see the key is the same.
    ap-group "New-Group"
       virtual-ap "secure"
       virtual-ap "guest"
       enet2-port-profile "NoAuthWiredPort"
       enet3-port-profile "NoAuthWiredPort"
       enet4-port-profile "NoAuthWiredPort"
       ap-system-profile "apsys_prof-uwk73"
    wlan virtual-ap "guest"
       aaa-profile "Captive_Portal-aaa_prof"
       ssid-profile "Captive_Portal-ssid_prof"
       vlan 1
    aaa profile "Captive_Portal-aaa_prof"
       initial-role "Captive_Portal-cp_prof"
       mac-server-group "cppm"
       radius-accounting "cppm"
       rfc-3576-server "10.10.10.200"
    aaa server-group "cppm"
     auth-server CPPM
    aaa authentication-server radius "CPPM"
       host "10.20.20.200"
       key "aruba"
    aaa rfc-3576-server "10.10.10.200"
       key "aruba"
  • 8.  RE: Raidus CoA not working
    Posted May 27, 2018 07:19 PM
    Your RADIUS server and RFC 3576 server should be the same IP and secret.
  • 9.  RE: Raidus CoA not working
    Posted May 27, 2018 07:25 PM
    Good catch there 10.20.20.200 vr rfc 10.10.10.200  LOL eyes play tricks on ya thanks  Now I just have to figure out when my kids go to snapchat they get disconnected from the wireless :)
