Network Management
RAM for airwave
  • 1.  RAM for airwave
    Posted Nov 15, 2018 12:21 PM
    Hi all,
    How much RAM is needed for airwave while installing on VMware? I am trying to install it using 4GB RAM for airWave. Is that suffice?
  • 2.  RE: RAM for airwave
    Posted Nov 15, 2018 12:32 PM
    Hi
    Take a look to this thread: https://community.arubanetworks.com/t5/Aruba-Solution-Exchange/AirWave-Server-Sizing-Calculator/ta-p/285961
    Also you can search for the Airwave's server sizing guide.
  • 3.  RE: RAM for airwave
    Posted Nov 15, 2018 02:47 PM
    4 GB RAM isn't going to be enough -> it'll be super slow.
    At least 8 GB RAM or more.  Depends on license count - but I run lab tests with setups of (for about 30-50 monitored devices, <100 simulated client count -> this isn't a ceiling, it's just a reference point):
    4 CPU, 8 GB RAM, 80 GB disk
    Note: 8.2.6.x/8.2.7.x versions have vmtoolsd already installed.  And when going the VM route, if the host is shared - ensure that AMP gets the priority for the correct I/O rates.  We've seen deployments on shared hosts where if AMP has to fight for disk priority, performance tanks since it's very database intensive for updating device status, client usage stats, etc.  And if it's a dedicated host, it only makes sense to run VM layer if using VM features like snapshots - otherwise its a waste of resources for the VM process overhead.
