Random WiFi drops
  • 1.  Random WiFi drops
    Posted Mar 04, 2016 12:04 PM
    We have several Aruba WAPs, models W-AP135 and W-AP225 in our environment. We recently have been experiencing seemingly random drops in connection for several users, followed by the inability to reconnect. This also goes away seemingly randomly. This doesn't happen on all access points connected to the controller and generally a reboot of the controller temporarily solves the issue. This is also accompanied by many WAPs in the organization showing high utilization in the console. Can anyone give me an idea of what to look at as I'm not the one who implemented the system and don't have a lot of experience with these APs?
    I've attached a snip of the what I'm seeing as high utilization in the console.
  • 2.  RE: Random WiFi drops
    Posted Mar 04, 2016 12:08 PM
    - You should not have to reboot a controller to make it work.  You probably have an RF issue.
    - Please PM me the tech support for the Virtual Controller of your IAPs.
  • 3.  RE: Random WiFi drops
    Posted Mar 10, 2016 10:09 AM
    cjoseph was able to help me get this resolved. This is the message he sent me.
    Your ap power is too high.
    arm
    wide-bands 5ghz
    min-tx-power 18
    max-tx-power 127
    Under RF and ARM your minimum transmit power should be 12 and the maximum should be 18.
    2.  You are not filtering broadcasts on any of your SSIDs.
    Edit all of your SSIDs and go to advanced.  Change broadcast filtering to ARP for all three SSIDS.
    After changing these two things my problem went away.
