last person joined: 3 hours ago
RAP-108 Question about instant software
  • 1.  RAP-108 Question about instant software
    Posted Oct 26, 2014 01:32 PM
    Hello Fello Airheads!
    I have a RAP-108 that doesnt seem to want to be an IAP. I believe that this has the ability to be an IAP but it wont load. Ive tried many different versions of iap software and all have the following output.
    apboot>
    apboot> upgrade os 192.168.10.79:ArubaInstant_Pegasus_6.4.2.0-4.1.1.0_46028
    eth0 up: 100 Mb/s full duplex
    DHCP broadcast 1
    DHCP IP address: 192.168.10.100
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.168.10.1
    DHCP DNS server: 192.168.10.1
    DHCP DNS domain:
    Using eth0 device
    TFTP from server 192.168.10.79; our IP address is 192.168.10.100
    Filename 'ArubaInstant_Pegasus_6.4.2.0-4.1.1.0_46028'.
    Load address: 0x2000000
    Loading: #################################################################
    done
    Bytes transferred = 8562652 (82a7dc hex)
    Invalid machine type in image: 0x1a
    **** ERROR: upgrade failed ****.
    apboot>
    the device is definitely a RAP-108 also:
    APBoot 1.2.7.14 (build 34663)
    Built: 2012-07-28 at 11:47:31
    Model: RAP-108/RAP-109
    CPU: AR9344 revision: 1.2
    Clock: 560 MHz, DDR rate: 450 MHz, Bus clock: 225 MHz
    DRAM: 128 MB
    POST1: passed
    Copy: done
    Flash: 32 MB
    Power: 802.3at POE
    PCI: scanning bus 0 ...
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 168c 0033 00002 01 00000004 00000000 00000000 00000000
    Net: eth0
    Radio: ar9590#0, ar9344#1
    I can however get the device to boot as a CAP/RAP with the mips32.ari image.
    Ive tried factory resetting it and all of that but it just never turns into an instant.  Any input would be greatly appreciated.
    Thanks!
    #AP225
  • 2.  RE: RAP-108 Question about instant software
    Posted Oct 26, 2014 04:48 PM
    Try the "os_info" command in AP-boot to see if there is an IAP-image available.
    You can switch to another partition by altering the "os_partition"-variable:
    setenv os_partition 1 (or 0)
    saveenv
    boot
    Are you sure the firmware image is valid? Maybe try re-downloading the firmware image from the support-website.
  • 3.  RE: RAP-108 Question about instant software
    Posted Oct 26, 2014 05:48 PM
    Can you provide the output of mfginfo from APBOOT?
    Sent from my iPhone
  • 4.  RE: RAP-108 Question about instant software
    Posted Oct 26, 2014 07:35 PM
    From the mfginfo command.
    mfginfo
    Inventory:
    Card 0: System
    Wired MAC : 6c:f3:7f:c5:13:86
    Wired MAC Count : 2
    Serial : BV0000215
    Date Code : 090812
    Wireless MAC : 6c:f3:7f:c5:13:87
    Wireless MAC Count : 1
    Country : CCODE-US-bc9c5785bebb6115a3331a6c308a4dbb79536633
    Card 1: CPU
    Assembly : AP-109
    Serial : BV0000215
    Date Code : 090812
    Major Rev : 01
    Minor Rev/Variant : 01
    apboot>
  • 5.  RE: RAP-108 Question about instant software
    Posted Oct 26, 2014 08:46 PM
    I think i figured it out!
    For some reason this device seems to be working just fine with the ORION software for a  IAP-92, IAP-93, IAP-105, IAP-175, RAP-3WN and RAP-3WN. This device is definitely a rap 100 series but when i loaded the orion code it booted perfectly and seems to be working just fine. I upgraded it through the web GUI also. Everything seems to be working as expected!!!
    Thanks everyone!
