RAP-108/9 VPN tunnel to Controller
  • 1.  RAP-108/9 VPN tunnel to Controller
    Posted Jan 31, 2013 06:24 PM
    So, just got a RAP-109 for a client. I'm planning to configure it in "Instant" mode and the use the VPN tunnnel for access to corporate resources.
    I've been reviewing the configuration guide, but I don't see any documentation specific to the RAP-10x. Is there any documentation on how to configure this, or is it just a plain old IPSec tunnel setup on the controller?
    Also, if it's in Instant mode and not configure as a traditional RAP do I need to whitelist it?
    oh, yeah, do I need to upgrade the controller to 6.2 for this to work as a VPN endpoint, or is that only is I use it as a traditional RAP.
    That's it. Any help would be appreciated.
  • 2.  RE: RAP-108/9 VPN tunnel to Controller
    Posted Feb 01, 2013 05:10 PM
    There are configs on both the IAP side and the controller.   The controller configuration is documented in the AOS 6.2 Users Guide Ch. 39 -- Instant AP VPN Support..
    You will need AOS 6.2 on the controller.   There was an earlier version (6.1.3.1-rn), however, it was a very early and limited release.  I would use 6.2.
  • 3.  RE: RAP-108/9 VPN tunnel to Controller
    Posted Feb 19, 2013 10:27 AM
    I can't seem to get the ipsec tunnel to work.  GRE works fine though.
  • 4.  RE: RAP-108/9 VPN tunnel to Controller
    Posted May 10, 2013 10:13 AM
    Well I managed to get the ipsec part working now.  Didn't work no matter what I did, and in frustration I rebooted the Instant and then it worked.
