RAP-109
  • 1.  RAP-109
    Posted Aug 24, 2015 03:14 PM
    I was told that the RAP 109s needed to be plugged into to a LAN switch with that switch providing a data network.  Once they were plugged in I would see them and haver the opportunity to provision them.  Well I do not see them in my Controller or Airwave.  The have link light and are drawing power.
  • 2.  RE: RAP-109
    Posted Aug 24, 2015 05:01 PM
    If the rap is in instant mode you need to convert it using the "instant" ssid but in order to see the ssid you the rap needs an IP
