RAP-109 captured area
  • 1.  RAP-109 captured area
    Posted Jan 09, 2014 05:07 AM
    RAP-109 config help ?
    There are 5 pieces RAP-109 controller
    No more than 10 meters shooting range
    what can be done?
  • 2.  RE: RAP-109 captured area
    Posted Jan 09, 2014 05:34 AM
    Hi arikunal.
    What exactly is your problem with the APs?
    The RAP-109 is not a controller in itself, but can "contain" a virtual controller if set up as instant-ap
    What do you mean by "10 meters shooting range"? Do you mean that theRF coverage area you get from the AP is 10 meter radius?
  • 3.  RE: RAP-109 captured area
    Posted Jan 09, 2014 07:13 AM
    There are no settings in radius
     show ap active
    Active AP Table
    Name                        IP Address     11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type  Flags  Uptime          Outer IP
    6c:f3:7f:c4:12:45           192.168.2.212  0            AP:HT:1/19/19        0            AP:HT:36+/22/22      105      a      6d:2h:6m:17s    N/A
    6c:f3:7f:c5:92:0c           192.168.2.220  5            AP:HT:11/19/19       2            AP:HT:44+/22/22      RAP-109  Aa     2d:15h:26m:58s  N/A
    6c:f3:7f:c4:12:26            192.168.2.216  0            AP:HT:11-/19/19      0            AP:HT:44+/22/22      105      a      6d:2h:7m:52s    N/A
    6c:f3:7f:c5:8f:d2            192.168.2.221  2            AP:HT:1/19/19        5            AP:HT:48-/22/22      RAP-109  Aa     1d:0h:27m:27s   N/A
    6c:f3:7f:c4:12:2c           192.168.2.213  0            AP:HT:11/19/19       0            AP:HT:48-/22/22      105      a      6d:2h:28m:45s   N/A
    6c:f3:7f:c4:11:2f            192.168.2.217  0            AP:HT:6/19/19        0            AP:HT:48-/22/22      105      a      6d:2h:6m:27s    N/A
    6c:f3:7f:c5:91:d4            192.168.2.222  0            AP:HT:1/19/19        1            AP:HT:36+/22/22      RAP-109  Aa     1d:0h:22m:1s    N/A
    6c:f3:7f:c4:12:41            192.168.2.218  0            AP:HT:1+/19/19       0            AP:HT:40-/22/22      105      a      6d:2h:30m:44s   N/A
    6c:f3:7f:c5:9b:f8            192.168.2.219  3            AP:HT:6/19/19        4            AP:HT:40-/22/22      RAP-109  Aa     2d:15h:27m:42s  N/A
    6c:f3:7f:c4:11:24            192.168.2.211  2            AP:HT:5-/19/19       0            AP:HT:44+/22/22      105      a      1d:0h:40m:45s   N/A
    6c:f3:7f:c4:11:19            192.168.2.215  0            AP:HT:6/19/19        0            AP:HT:36+/22/22      105      a      6d:2h:33m:28s   N/A
  • 4.  RE: RAP-109 captured area
    Posted Jan 09, 2014 08:17 AM
    By radius I meant radius as the radius of a circle, not the radius serve :)
    Also I still don't understand what your problem is and what you want to achieve?
  • 5.  RE: RAP-109 captured area
    Posted Jan 09, 2014 09:17 AM
    There are 4 Access Point RAP-109 model in our head Office.
    Gravitational fields of these devices does not exceed 10 meters.
    We made the necessary settings on the controller but there wasn’t change in the gravitational field.
    What we need to do strengthen the gravitational field.
  • 6.  RE: RAP-109 captured area
    Posted Jan 09, 2014 09:34 AM
    Are you using Google Translate for this? Becase both "Shooting Range" and "Gravitational Field" does not make any sense for an AP. I am guessing that you mean that you have trouble with the APs not transmitting at a power where you can communicate with them at a distance greater than 10 meters?
    This sounds weird.. You can check the EIRP power setting in your ARM profile.
    Go to Configuration > AP Group > RF Management > 802.11a/g > Adaptive Radio Management (ARM)
    The settings you are looking for is Max Tx EIRP and Min Tx EIRP.
    Make sure that the Max Tx EIRP is set to 127 and if it allready is set to this, you could try to increase the Min Tx EIRP in small increments. Maybe for some reason your ARM is setting the TX strength to a very low value.
  • 7.  RE: RAP-109 captured area
    Posted Jan 09, 2014 10:16 AM
  • 8.  RE: RAP-109 captured area
    Posted Jan 09, 2014 03:48 PM
    arikunal wrote:
    Uncheck client-aware
    Uncheck arm-over the air updates
    Unchek multi-band scan
    Change "Allowed Bands for 40mhz Channels" to "a-only"
  • 9.  RE: RAP-109 captured area
    Posted Jan 10, 2014 01:57 AM
    Thank you to everyone
    We solve problems
  • 10.  RE: RAP-109 captured area
    Posted Jan 10, 2014 09:36 AM
    What was the spolution?
  • 11.  RE: RAP-109 captured area
    Posted Jan 09, 2014 01:06 PM
     show ap active
    Active AP Table
    From this output it seems that if you are in North America it seems that Arm is already set to push the MAX / or they were broadcasting at max then.
    At 10meters what is the SNR readings you are getting?
    At the same time would you be able to give us a floor plan with all the AP's the location of all the AP's you are managing (are they on the same controller - RAP or campus)?
