RAP-109: Not broadcasting Instant SSID
  • 1.  RAP-109: Not broadcasting Instant SSID
    Posted Oct 02, 2014 05:33 PM
    So I have a RAP-109 that refuses to broadcast its instant SSID for setup.
    It has an IP (eth0) and it is plugged into a switch-- however, the two wifi lights are solid amber.  I have factory reset the thing a couple of times now just in case... anyohe have any thoughts?  It is my first time setting up an RAP but it doesn't come across as something that should be this difficult.
    Garett LaBerge
  • 2.  RE: RAP-109: Not broadcasting Instant SSID
    Posted Oct 02, 2014 05:51 PM
    Solved.  So I have an IAP-225 and a IAP-115 in my home.  The 225 acts as a VC-- so the RAP was trying to join them but there was an image mismatch (of course there was)-- so I just unplugged the 225 and 115 and the SSID came right up.
    Good to know for setting these up in the future.
    Garett LaBerge
