RAP-109 port configuration
  • 1.  RAP-109 port configuration
    Posted Jul 20, 2015 01:50 AM
    Hi, all!
    Help me please with configuration.
    I have 2 x RAP-109.
    Internet <-> (port ENET 0) RAP-109 (port ENET 1) <-> (port ENET 0) RAP 109
    First RAP connect with Unternet from uplink port ENET 0, with port ENET 1 connect with other RAP-109.
    Port ENET 0 have to be with static IP, from port ENET 1 have to transmit IP from internal DHCP-server IP-address to other RAP-109.
    First RAP have to work like wireless router.
    Have to be 1 SSID and 1 internal network for 2 RAPs and for users.
    Thank you!
  • 2.  RE: RAP-109 port configuration
    Posted Jul 20, 2015 03:15 AM
    Why are you connecting them physically like that? What are you trying to accomplish?
  • 3.  RE: RAP-109 port configuration
    Posted Jul 20, 2015 03:53 AM
    Hi!
    This connection due to the specific area.
    I want to have 1 port of RAP connected to Internet, other port is connected to second RAP.
    1 port have to have it's own IP-address (from ISP), other port for internal network (for connect second RAP).
    AP's have to work virtual controller (small network - 2 AP's)
  • 4.  RE: RAP-109 port configuration
    Posted Jul 20, 2015 04:19 AM
    You cannot do this.  You need an external DHCP server.  The internal DHCP server of an IAP cannot give out addresses for the management IP address of a different AP in the same cluster.
  • 5.  RE: RAP-109 port configuration
    Posted Jul 20, 2015 04:24 AM
    OK.
    Which solution you can advice in this situation?
    (when I have 2 AP's, 1 IP-address from ISP and have to have internal network with 1 SSID)
    Thank you!
  • 6.  RE: RAP-109 port configuration
    Posted Jul 20, 2015 04:26 AM
    Do you have a router at the site that the ISP provided?
  • 7.  RE: RAP-109 port configuration
    Posted Jul 20, 2015 04:30 AM
    ISP give me only 1 IP-address.
    But in IAP_User_Guide I find Deployment picture, which almost identical with my deployment.
    (That's why I take RAP but not IAP AP's)
    Thank you!
  • 8.  RE: RAP-109 port configuration
    Posted Jul 27, 2015 03:13 AM
    Hi, all!
    I have success with this issue.
    Just configure wired_port_profile for downlink.
    In AP's tab I see 2 access points with different IP's:
    1AP - static IP (to ISP)
    2AP - IP received from internal DHCP-server
    Thank you!
