  • 1.  Rap-155
    Posted Sep 17, 2013 04:50 PM
    I am trying to get a RAP-155 working for one of our mobile demo kits and I thought I read somewhere the USB551L was supported but now I can't find out how to set it up.  Cany anyone give me any insight?  I have to RAP configured and working on the wire but now just trying to get the Cellular to work.  Thank you for any help you can give.
    #RAP155
  • 2.  RE: Rap-155
    Posted Sep 17, 2013 08:11 PM
    Is this the Novatel MC551L
    #RAP155
  • 3.  RE: Rap-155
    Posted Sep 17, 2013 08:15 PM
    Yes that is correct.
    Sent from my iPhone
    #RAP155
  • 4.  RE: Rap-155
    Posted Sep 17, 2013 08:23 PM
    Here are some notes from internal testing of the Stick from earlier this year.
    Are you provisioning along these lines ?
    JF
    Service Provider
    Product
    Std & Throughput
    Provisional params
    Network-switch to 4G-3G
    Verizon
    Novatel MC551L - Qualcomm MDM9600
    CDMA 1xEV–DO Rev. A/Rev. 0: 800/1900 MHz
    LTE CDMA (700MHz)
    For 4G:
    usb_type = ether(9)
    cellular_nw_preference=4g_only
    usb_dev=0x1410b001
    For 3G:
    usb_type = ether-3g (9)
    cellular_nw_preference=3g_only usb_dev=0x1410b001
    Operates in either 4G or 3G:
    cellular_nw_preference=auto
    usb_dev=0x1410b001
    #RAP155
  • 5.  RE: Rap-155
    Posted Sep 17, 2013 08:26 PM
    I have not tried those exact settings. I will try that in the morning and let you know the results. Thank you!
    Sent from my iPhone
    #RAP155
  • 6.  RE: Rap-155
    Posted Sep 17, 2013 08:29 PM
    Anytime John.
    Good luck tomorrow!
    JF
    #RAP155
  • 7.  RE: Rap-155
    Posted Sep 18, 2013 07:38 AM
    Worked like a champ!  Thank you again for the guidance!
    #RAP155
  • 8.  RE: Rap-155
    Posted Sep 18, 2013 08:34 AM
    Great to hear.
    Thanks for the update.
    JF
    #RAP155
  • 9.  RE: Rap-155
    Posted Oct 07, 2014 03:28 PM
    I am having same problem connecting RAP-155 with a USB-551L Verizon USB stick.
    What settings would I need in the web-gui in order to get this to work?
    #RAP155
  • 10.  RE: Rap-155
    Posted Nov 21, 2014 04:45 PM
  • 11.  RE: Rap-155
    Posted Dec 16, 2014 07:53 PM
    Which  version of the code was USB551L this tested on?
  • 12.  RE: Rap-155
    Posted Dec 16, 2014 08:10 PM
    I tested on 6.3.1.8
