Aruba Apps
last person joined: 14 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
RAP-155 use same network wired name when configured more than 1 RAP
  • 1.  RAP-155 use same network wired name when configured more than 1 RAP
    Posted Nov 30, 2015 08:41 AM
     I configured RAP-155 for remote Access, and I have the RAP around 4-5 devices
    I assigned each RAP per 1 AP-Group.
    I work fine for SSID Name , there is no issue about this
    BUT when connected via wired , it use same name for all RAP.
    How can I set diferent name for each wired network ?
    Thank so much
    Warinda
  • 2.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Nov 30, 2015 09:35 AM
    Can you show us a screenshot?
  • 3.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Nov 30, 2015 09:53 PM
    please find the screenshot as attached file.
    PS. all of AP-Group that use RAP-155 when connected via wired  they got same name "NSGT-PINTONG"
    Thank you
    Warinda
    Attachment(s)
    zip
    screen_shot.zip   421 KB 1 version
  • 4.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Nov 30, 2015 10:30 PM
    Is that the name of your internal domain ?
  • 5.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Nov 30, 2015 10:35 PM
    No, it is the SSID name for the first RAP-155 that we had configured before,
    As we seperate each RAP to 1 AP-Group , but when connecting via wired it shows same name.
  • 6.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Nov 30, 2015 10:42 PM
    Are you using the same VLAN on wired and on that SSID ?
  • 7.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Nov 30, 2015 10:45 PM
    Yes it is, I used same VLAN on wired and SSID but different VLAn for each AP-Group
    NSGT-PINTONG -- VLAN 57
    SDD-Rempote -- VLAN 59
  • 8.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Nov 30, 2015 10:58 PM
    Have you tried changing the name of that SSID?
    And if it gets reflected on the wire side.
    The information listed in the wire connection status is usually obtained from the DNS server
  • 9.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Nov 30, 2015 11:10 PM
    Yes I did change, even I changed Whitelist from AP Group Remote-SDD to Remote-L2
    the SSID showed  NSGT-L2Remote but wired connect still show NSGT-PINTONG.
    I'm wondering why the wired connection used that name? and where it gets from?
    ** we use internal DNS from controller and no any that name from our DNS server
  • 10.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Dec 01, 2015 05:25 AM
    Internal DNS from the controller ?
    The controller doesn't have DNS capabilities .
    What are you using for DHCP ?
  • 11.  RE: RAP-155 use same network wired name when configured more than 1 RAP
    Posted Dec 01, 2015 05:46 AM
    Sorry about the internal DNS, I intened to say we don't any name from DNS , when setting AP Group on Aruba controller , in Configuration we specificed the SSID name on Wireless LAN but no any name setting about Wired AP.
      Then I suspected that it will be used the same name from  SSID but for RAP-155 it was not as I expected.
    Do you have any idea to specific the name for Wired AP?
    Thank you
