RAP 203RP stuck in performing conversion
  • 1.  RAP 203RP stuck in performing conversion
    Posted Aug 25, 2017 12:08 PM
    setup : 2 x 72xx controllers (master - local) running latest 6.4 fw
    rap 203RP
    When provisioning the rap on the internal network : no problem at all.
    When provisioning via the internet...  different story...  The rap seems stuck in performing conversion...
    How is the setup done?  The rap connects to a public ip, which is nat'ed to the vrrp adress.  Port udp 4500 is allowed on the firewall.   I see the packets logged in the firewall tracker as allowed.  And see the rap as down in monitoring on the controller with the public and internal ip address.  So it's whitelisted btw.
    At the moment i'm guessing the vrrp address is the issue?  When provisioning, on the rap i see i need to specify the master controller's adress.  The vrrp address however currently points to the local controller's ip...  Could this be the reason?
  • 2.  RE: RAP 203RP stuck in performing conversion
    Posted Aug 25, 2017 12:12 PM
    Per the datasheet, the 203RP requires ArubaOS 6.5.2 or greater.
  • 3.  RE: RAP 203RP stuck in performing conversion
    Posted Aug 25, 2017 12:51 PM
    My apologies, i was mistaken.  Just checked and we're running 6.5.4.0.
  • 4.  RE: RAP 203RP stuck in performing conversion
    Posted Aug 25, 2017 01:32 PM
    Do you have any remote APS that work?
    How are you doing the conversion?
  • 5.  RE: RAP 203RP stuck in performing conversion
    Posted Aug 25, 2017 01:37 PM
    Not 'externally'.  This is actually the first time we're doing this.
    When you reset an 203RP, after restarting it broadcasts an ssid.  We login, choose mobility controller, conversion to rap, enter the public ip address of the vrrp and hit go.
  • 6.  RE: RAP 203RP stuck in performing conversion
    Posted Aug 25, 2017 01:41 PM
    You should try making the 1:1 NAT point to the actual ip address of a controller, instead of the VRRP.
