RAP-2G Failed to connect with Controller
  • 1.  RAP-2G Failed to connect with Controller
    Posted Sep 02, 2013 03:58 AM
    Guys,
    Am referencing this solution
    http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Rc-error-ike-xauth-authorization-failed/m-p/12115#M4994
    I seem to have the same error but for some reason, I cannot see the solution given by cjoseph. Perhaps someone here can help me (since cjoseph is not currently online) and its rather urgent.
    Am getting the same error
    Sep 2 08:25:45 <localdb 133006> <ERRS> |localdb| User 00:0b:86:c3:50:9d Failed Authentication
    Sep 2 08:25:45 <isakmpd 103048> <ERRS> |ike| IKE XAuth failed for 00:0b:86:c3:50:9d
    fmo
  • 2.  RE: RAP-2G Failed to connect with Controller
    Posted Sep 02, 2013 05:21 AM
    To add to the whitelist, you'll need to go to Configuration > Wireless > AP Installation > Whitelist and add the mac into there.
    Make sure you have a local nat pool configured as well.
    :smileyhappy:
  • 3.  RE: RAP-2G Failed to connect with Controller
    Posted Sep 02, 2013 05:24 AM
    I had alresdy done that, but my AP was still not visible under the ALL APs tab. I had to restart the Controller several times...then it worked.
    Thank you.
