RAP-2WG issue with AOS 6.4.2.12
  • 1.  RAP-2WG issue with AOS 6.4.2.12
    Posted Sep 13, 2015 11:11 PM
    We are having problem after upgrading a Aruba650 Controller from AOS 5.0.2.1 to AOS 6.4.2.12
    All RAPs Can't be connected To Controller
    After Resetting the RAP-2WG to factory defaults does not resolve the issue.
    The RAPs show as upgrading in their status,and RcI Flags then they just reboot and try to upgrade again.
    My RAP-2WGs have AOS 5.0.2.1 on the backup partition.
  • 2.  RE: RAP-2WG issue with AOS 6.4.2.12
    Posted Sep 13, 2015 11:16 PM
    The last version of ArubaOS that supports the Rap2WG is ArubaOS 6.3  http://www.arubanetworks.com/support-services/end-of-life/#AccessPoints
  • 3.  RE: RAP-2WG issue with AOS 6.4.2.12
    Posted Sep 14, 2015 12:16 AM
  • 4.  RE: RAP-2WG issue with AOS 6.4.2.12
    RAP-2 is not supported on 6.4
    Tim
