RAP-2wg's failing to register to controller
  • 1.  RAP-2wg's failing to register to controller
    Posted Sep 21, 2012 12:19 PM
    hi guys,
    i've got some RAP5's registered to a test system, and we're rolling out a new solution for remote voice agents using  the rap-2wg's.
    However I cannot get them to register successfully to the existing test controller.
    We're running version 6.1.3.3 on the test controller, the RAPs come with 5.0.4.0 out of the box.
    When they initially connect, I can see an upgrade attempt, but then they simply refuse to connect after the reboot.
    I see the following in the logs after running 'logging level debugging ap-debug xyz process approc'
    Sep 21 16:11:23 :311014:  <ERRS> |AP 00:0b:86:67:55:55@1.1.1.25 sapd|  Local write failed: Success.
    Sep 21 16:11:23 :311014:  <ERRS> |AP 00:0b:86:67:55:55@1.1.1.25 sapd|  ncftpget mips64.ari: no space.
    Sep 21 16:11:23 :311014:  <ERRS> |AP 00:0b:86:67:55:55@1.1.1.25 sapd|  FTP Failed: 3. Trying FTP again for STRAP
    Sep 21 16:11:23 :311013:  <ERRS> |AP 00:0b:86:67:55:55@1.1.1.25 sapd| Image upgrade failed; details follow.
    Sep 21 16:11:23 :311014:  <ERRS> |AP 00:0b:86:67:55:55@1.1.1.25 sapd|  killall: ntp: no process killed
    Sep 21 16:11:23 :311014:  <ERRS> |AP 00:0b:86:67:55:55@1.1.1.25 sapd|  ERROR: File size exceeded 5242880 bytes
    Sep 21 16:11:23 :311014:  <ERRS> |AP 00:0b:86:67:55:55@1.1.1.25 sapd|  FTP Failed: 3. Trying TFTP.
    Sep 21 16:11:23 :311014:  <ERRS> |AP 00:0b:86:67:55:55@1.1.1.25 sapd|  Flash Image upgrade failed: 255
    Sep 21 16:11:34 :311002:  <WARN> |AP 00:0b:86:67:55:55@1.1.1.25 sapd|  Rebooting: SAPD: Reboot after image upgrade
    Sep 21 16:11:34 :303086:  <ERRS> |AP 00:0b:86:67:55:55@1.1.1.25 nanny| Process Manager (nanny) shutting down - AP will reboot!
    It appears the upgrade fails as there isn't enough room on the RAP2's. I can do a hard reset on them, and redo the process, but with the same results.
    i've tested two AP's at this stage, no difference.
    Any ideas??
    Many thanks,
    Liamo
  • 2.  RE: RAP-2wg's failing to register to controller
    Posted Sep 21, 2012 12:20 PM
    I also meant to say, I should have plenty of licenses available on the controller:
    I've got 12 remaining RAP capacity....
