RAP 2WN Licensing
  • 1.  RAP 2WN Licensing
    Posted Aug 07, 2013 01:10 PM
    I try to configure a RAP 2WN like a CAP in Aruba OS 6.1.3.7, Can I do this without problems? I try to do it but when I provision that RAP with their respective AP Group (vap, vlan, dhcp, etc.), I can see it in the controller but i can´t see the SSID irradiated. In the CLI, this RAP has "IL" Flags, that stand for inactive and unlicensed, I have AP, PEF and RF Protect licenses enough. In case that i need a license, what license is what i need?
    Thanks in advance.
    Alberto.
  • 2.  RE: RAP 2WN Licensing
    Posted Aug 07, 2013 01:21 PM
    Please check for command "show license" and show ap license-usage" on the controller to make we have the enough license to add one more Campus AP.  You may need to make sure counf of ap license, pef and RFP license match otherwise AP would not come up.
    Show log system all output should give you more info about the RAP which shows inactive.
    Also it is worth to check the default ap-group config to make sure we have the VAP profile and radio profile enabled.
    Thank you.
  • 3.  RE: RAP 2WN Licensing
    Posted Aug 07, 2013 01:40 PM
    This is the ap license usage:
    (Aruba3400) #show ap license-usage
    AP Licenses
    Type Number
    AP Licenses 256
    RF Protect Licenses 256
    PEF Licenses 256
    Overall AP License Limit 256
    AP Usage
    Type Count
    CAPs 0
    RAPs 0
    Tunneled nodes 0
    Total APs 0
    Remaining AP Capacity
    Type Number
    CAPs 64
    RAPs 256
    The logs are in the attachments.
    The RAP was provisioned with a AP group tested witn another AP, and works fine.
    Thanks.
  • 4.  RE: RAP 2WN Licensing
    Posted Aug 07, 2013 01:47 PM
    I don't think that logs are attached to the message. Can i send you to your e-mail?
  • 5.  RE: RAP 2WN Licensing
    Posted Aug 07, 2013 02:03 PM
    Yes, Please. Thanks!
  • 6.  RE: RAP 2WN Licensing
    Posted Aug 07, 2013 05:39 PM
    Which is your e-mail?
  • 7.  RE: RAP 2WN Licensing
    Posted Aug 07, 2013 05:41 PM
    Please email me at srirams@arubanetworks.com.
  • 8.  RE: RAP 2WN Licensing
    Posted Aug 08, 2013 10:01 AM
    Thanks much for the log info.
    From controller logs, we could notice below messages stating RAP-2 can be used only as a remote ap.
    As Jeff stated, RAP-2 is not supported or not recommended to bring up as Campus AP.
    ---------------------------------------Sniped----------------------------------------------------------------------------------------------------------------------------------------------------------------
    Aug  7 05:12:19  stm[1561]: <305043> <WARN> |stm|  AP 00:0b:86:c3:5e:44 (type RAP-2WG) can only be used as a remote AP.
    Aug  7 05:13:36  sapd[562]: <311002> <WARN> |AP 00:0b:86:c3:5e:44@10.1.145.254 sapd|  Rebooting: SAPD: Rebooting after provisioning
    Aug  7 05:13:37  nanny[532]: <303086> <ERRS> |AP 00:0b:86:c3:5e:44@10.1.145.254 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Aug  7 05:15:55  nanny[534]: <303022> <WARN> |AP RAPtest@10.1.145.254 nanny|  Reboot Reason: AP rebooted Wed Aug 7 05:13:37 GMT 2013; SAPD: Rebooting after provisioning
    Aug  7 05:16:19  stm[1561]: <305043> <WARN> |stm|  AP RAPtest (type RAP-2WG) can only be used as a remote AP.
    Aug  7 05:24:23  sapd[568]: <311002> <WARN> |AP RAPtest@10.1.145.254 sapd|  Rebooting: SAPD: Reboot requested by controller
    Aug  7 05:24:23  nanny[534]: <303086> <ERRS> |AP RAPtest@10.1.145.254 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Aug  7 05:26:42  nanny[549]: <303022> <WARN> |AP RAPtest@10.1.145.254 nanny|  Reboot Reason: AP rebooted Wed Aug 7 05:24:23 GMT 2013; SAPD: Reboot requested by controller
    Aug  7 05:27:07  stm[1561]: <305043> <WARN> |stm|  AP RAPtest (type RAP-2WG) can only be used as a remote AP.
    ------------------------------------Sniped--------------------------------------------------------------------------------------------------------------------------------------------------------------------
    Thanks!
  • 9.  RE: RAP 2WN Licensing
    Posted Aug 08, 2013 03:47 AM
    @Alberto García wrote:
    hi Alberto
    please refer to this other Airheads thread , RAP-2 as campus AP is no longer supported as of 6.1.x. You can change to RAP-3, or, configure the RAP-2 back to being remote AP.
    regards
    -jeff
