last person joined: 3 hours ago
RAP-3 h/w factory reset
  • 1.  RAP-3 h/w factory reset
    Posted Jan 23, 2015 08:45 AM
    How to hardware reset RAP-3 ? I dont see any reset button
  • 2.  RE: RAP-3 h/w factory reset
    Posted Jan 23, 2015 08:49 AM
    The reset button is on the bottom of the RAP-3.
  • 3.  RE: RAP-3 h/w factory reset
    Posted Jan 23, 2015 08:54 AM
    Nice , hard to spot lol appreciate
  • 4.  RE: RAP-3 h/w factory reset
    Posted Jan 23, 2015 09:50 AM
    one more quick question, what's the reset procedure ? I tried to keep the reset button for 3sec than 10 sec nothing happened... Also kept it pressed during reboot, same thing. Please advise
  • 5.  RE: RAP-3 h/w factory reset
    Posted Jan 23, 2015 10:27 AM
    To reset the RAP-3:
    1. Remove power to RAP
    2. Insert a small object into the reset hole and press and hold the button
    3. Continue holding the button in while powering on the RAP-3.
    4. Hold this for up to 10 seconds.  The lights on the RAP will flash.
