Wireless Water Cooler
Hang out and socialize with other community members in this off topic forum. Everything from industry trends to hobbies and interests are welcomed!
RAP-3 Reboot - Bootstrap - Heartbeats - ipsec timeouts
  • 1.  RAP-3 Reboot - Bootstrap - Heartbeats - ipsec timeouts
    Posted Jun 13, 2018 11:28 AM
    Airpeople,
    I am using RAP3s at a couple of thousand locations.  I am not using WiFi on them at all, only the wired ports.  I want to understand how they react to poor or absent connectivity to their primary lms.  Aside from that, are there any circumstances where a RAP could be up and pingable on it's local pool address, but they clients themselves cannot communicate for an extended perion of time.  In my situation, the tunnel for the wired port clients is layer 2 all the way to the controller green zone subnet. (default gateway outside of controller).  We had a situation where multiple clients in the same geographic area were unable to obtain an IP address, yet the RAP remained up (pingable from the controller).
    I'm told everything I need to know is in the system profile, so here it is:
    AP system profile "HBA-TPA-sysprof"
    Parameter Value
    RF Band g
    RF Band for AM mode scanning all
    Native VLAN ID 1
    Tunnel Heartbeat Interval 1
    Session ACL ap-uplink-acl
    Corporate DNS Domain N/A
    SNMP sysContact N/A
    LED operating mode (11n/11ac APs only) normal
    LED override Disabled
    Driver log level warnings
    Console log level emergencies
    SAP MTU N/A
    RAP MTU 1200 bytes
    LMS IP 192.76.82.76
    Backup LMS IP 137.188.108.63
    LMS IPv6 N/A
    Backup LMS IPv6 N/A
    LMS Preemption Enabled
    LMS Hold-down Period 600 sec
    LMS ping interval 20
    Remote-AP DHCP Server VLAN N/A
    Remote-AP DHCP Server Id 192.168.11.1
    Remote-AP DHCP Default Router 192.168.11.1
    Remote-AP DHCP DNS Server N/A
    Remote-AP DHCP Pool Start 192.168.11.2
    Remote-AP DHCP Pool End 192.168.11.254
    Remote-AP DHCP Pool Netmask 255.255.255.0
    Remote-AP DHCP Lease Time 0 days
    Remote-AP uplink total bandwidth 0 kbps
    Remote-AP bw reservation 1 N/A
    Remote-AP bw reservation 2 N/A
    Remote-AP bw reservation 3 N/A
    Remote-AP Local Network Access Disabled
    Flex Radio Mode 2.4GHz-and-5GHz
    IPM activation Disabled
    IPM power reduction steps with priorities N/A
    Bootstrap threshold 8
    Double Encrypt Disabled
    Dump Server N/A
    Heartbeat DSCP 0
    Management DSCP N/A
    IP DSCP to VLAN 802.1p priority mapping N/A
    Maintenance Mode Disabled
    Maximum Request Retries 10
    Request Retry Interval 10 sec
    Number of IPSEC retries 85
    Secondary Master IP/FQDN N/A
    AeroScout RTLS Server N/A
    RTLS Server configuration N/A
    RTLS Server Compatibility Mode Enabled
    Slow Timer Recovery by rebooting itself Enabled
    Telnet Disabled
    Disable RAP Tftp Image Upgrade Disabled
    Spanning Tree Disabled
    AP multicast aggregation Disabled
    AP ARP attack protection Disabled
    AP multicast aggregation allowed VLANs none
    Console enable Enabled
    AP Console Protection Enabled
    AP Console Password ********
    Password for Backup ********
    AP USB Power override Disabled
    RF Band for Backup all
    Operation for Backup off
    BLE Endpoint URL N/A
    BLE Auth Token N/A
    BLE Operation Mode Disabled
    Health Check Disabled
    Health Check Parameter mode ping packet-size 32 burst-size 5 report 60 frequency 10 retries 3
    Radio and Nbr Stats Report Period 30 minutes
    Radio and Nbr Measurement Duration 5 minutes
    Radio and Nbr Stats Report Enabled Disabled
  • 2.  RE: RAP-3 Reboot - Bootstrap - Heartbeats - ipsec timeouts
    Posted Jun 15, 2018 05:04 AM
    I would expect that if the RAP loses heartbeats, it would stop servicing client traffic. For WLAN, the SSID (depending on the setting: Always/Backup/Normal) will disappear or come up. For the wired, I'm not really sure. Fact of life is that if the controller is unreachable, the wireless frames will not traverse to the controller (and vice versa). In case the RAP cannot reach the controller for a longer time, it will restart in the hope that it will be better after that.
    Probably the best is to work with Aruba TAC (via your partner) as they can go deeper into your specific situation. Some of the retry and interval parameters can be changed to possible better match your environment, but I would not change unless advised by Aruba TAC.
