RAP 3 with amber WLAN light
  • 1.  RAP 3 with amber WLAN light
    Posted Nov 10, 2014 06:09 AM
    I've got a RAP3 connected over the internet to a 3200XM controller. Using the LAN pors on the RAP 3 I can connect to our headquarters LAN through the 3200XM controller. However I can't get the WLAN to work on the RAP3.
    I've greated a new WLAN for the AP Group which the RAP 3 is asigned to. The forwarding mode for the AP Group is set to Tunnel, intended for Internal use with Open Authentication. When the RAP connects to the Controller the WLAN light is amber and no WLAN avaliable.
    Before converting the RAP3 I updated its software, the version of the controller software is also updated to 6.2
    Any suggestions ?
    thanks
  • 2.  RE: RAP 3 with amber WLAN light
    Posted Nov 10, 2014 06:22 AM
    Does the VLAN in the VAP exist on the controller?
    When you type "show ap database" are there any flags next to the RAP3's entry?
  • 3.  RE: RAP 3 with amber WLAN light
    Posted Nov 25, 2014 07:04 AM
    Hi, Sorry for taking so long to reply. My licence exprired just after posting the problem.
    When I ran show ap database i can see Flag R-c2 for this RAP.
    The RAP is assigned to an AP Group called Default, it wireless LAN settings are set to use VLAN 1 and this is assigned to Port 3 which is NATed out to the internet.
    Only one port is connected to our LAN, Port 3, and this is working for the LAN connection from the RAP.
  • 4.  RE: RAP 3 with amber WLAN light
    Posted Nov 25, 2014 07:21 AM
    When I run show "ap-group default" I get the follwoing
    AP group "default"
    Parameter                                Value
    Virtual AP                               Staff_Remote-vap_prof
    802.11a radio profile                    default
    802.11g radio profile                    default
    Ethernet interface 0 port configuration  default
    Ethernet interface 1 port configuration  default
    Ethernet interface 2 port configuration  shutdown
    Ethernet interface 3 port configuration  default
    Ethernet interface 4 port configuration  shutdown
    AP system profile                        default
    802.11a Traffic Management profile       N/A
    802.11g Traffic Management profile       N/A
    Regulatory Domain profile                default
    RF Optimization profile                  default
    RF Event Thresholds profile              default
    IDS profile                              default
    Mesh Radio profile                       default
    Mesh Cluster profile                     N/A
    Provisioning profile                     N/A
    AP authorization profile                 default
    (BallinaHQ) #
  • 5.  RE: RAP 3 with amber WLAN light
    Posted Dec 20, 2014 08:17 AM
    got this solved?
    have you tried your vap on another AP to check if it is correct?
