RAP-335 ENET0 unusable?
  • 1.  RAP-335 ENET0 unusable?
    MVP
    Posted Feb 14, 2019 08:42 AM
    After configuring a few dozen AP335 as remote APs I've now had 3 times that a RAP would no longer boot from its ENET0.
    Powercycling a RAP (physically unplugging the cable) that is stuck like that does not help resolve the issue.
    Interrupting the APboot and triggering DHCP several times does not work (or help) either.
    apboot> dhcp
    eth0: No link.
    eth1 Waiting for PHY auto negotiation to complete......... TIMEOUT !
    eth1: No link.
    apboot> dhcp
    eth0: No link.
    eth1: No link.
    apboot> dhcp
    eth0: No link.
    eth1: No link.
    Also letting the entire boot run its course does not help.
    Aruba watchdog daemon started [1 thread(s)]
    LLDP not sent yet, DHCP is waiting
    net.ipv4.conf.all.arp_notify = 1
    Getting an IP address...
    Not LACP mode, adding 30 seconds updelay!
    The fix for now has always been to boot once from ENET1, this has always resolved the issue.
    Starting DHCP
    [   39.122527] asap_firewall_forward: br0, insufficient headroom, require 68, but has 16, skb data length 60. mac header: dst mac FF:FF:FF:FF:FF:FF, src mac 20:A6:CD:CF:50:A4, etype 2054
    [   41.325524] asap_firewall_forward: br0, insufficient headroom, require 68, but has 16, skb data length 60. mac header: dst mac FF:FF:FF:FF:FF:FF, src mac 20:A6:CD:CF:50:A4, etype 2054
    [   43.332519] asap_firewall_forward: br0, insufficient headroom, require 68, but has 16, skb data length 60. mac header: dst mac FF:FF:FF:FF:FF:FF, src mac 20:A6:CD:CF:50:A4, etype 2054
    net.ipv4.conf.all.arp_notify = 0
    net.ipv4.conf.br0.arp_notify = 1
    192.168.50.12 255.255.255.0 192.168.50.1
    Running ADP...Done. Master is <our master>
    After having booted from ENET1, now also ENET0 works again.
    Starting DHCP
    Running ADP...Done. Master is ...
    Problem is, these APs are to be installed where we can not easily unplug/replug those APs. I'd also rather not simply use ENET1 as in future models/deployement ENET1 might not be usuable to draw POE power from. Ans besides from that, I a not confident this issue is limited to ENET0 only.
    Anybody got an idea what is going wrong here?  What could trigger an AP to pull down an interface across powercycles?
  • 2.  RE: RAP-335 ENET0 unusable?
    Posted Feb 20, 2019 05:25 AM
    hi Koen
    these messages
    are always bad (and are a bug) - what s/w version are you on and whats the rap topology (split tun, bridge etc.)
  • 3.  RE: RAP-335 ENET0 unusable?
    MVP
    Posted Feb 20, 2019 05:45 AM
    8.4.0.0 with all tunneled, although I doubt that matters much since my issue is even getting the AP up at all.
    Any info on what headroom warning is actually about?
  • 4.  RE: RAP-335 ENET0 unusable?
    Posted Feb 21, 2019 11:42 PM
    the headroom message is a low level bug in packet assembly, it should not be happening - please raise a ticket on it.
  • 5.  RE: RAP-335 ENET0 unusable?
    Posted Mar 01, 2019 07:56 AM
    I installed 8.4.0.0 and have this message too on a IAP-305 converted into RAP (right after conversion).
    But don't know if it implies issue for the AP as I'm troubleshooting something else.
  • 6.  RE: RAP-335 ENET0 unusable?
    Posted Sep 06, 2019 05:55 AM
    Did anoyone find a solution to this? I too am reciving these error messages right after converting an AP to a Remote.
    Running 8.4.0.1
    Thanks.
