RAP-3's coming up as air monitors after 6.3.1.4 upgrade.
  • 1.  RAP-3's coming up as air monitors after 6.3.1.4 upgrade.
    Posted Apr 10, 2014 08:18 PM
    Anyone have any ideas why my RAPs would be coming up as air monitors after upgrading to 6.3.1.4? They were working fine pre-upgrade.
  • 2.  RE: RAP-3's coming up as air monitors after 6.3.1.4 upgrade.
    Posted Apr 10, 2014 08:27 PM
    Are those under the same AP-Group and Controller ?
    Confirm how your RF-Profile is configured as an Air Monitor ?
    Did you do guys do a save config before rebooting the controller ?
  • 3.  RE: RAP-3's coming up as air monitors after 6.3.1.4 upgrade.
    Posted Apr 10, 2014 08:36 PM
    same AP group, same controller, we did save the config before rebooting and they are set to ap-mode.
  • 4.  RE: RAP-3's coming up as air monitors after 6.3.1.4 upgrade.
    Posted Apr 10, 2014 09:02 PM
    Do you have any ap specifc configuration ?
    Are all the RAPs under that AP-Group showing up as Air Monitor  when you run the show  ap  active type air-monitor ?
  • 5.  RE: RAP-3's coming up as air monitors after 6.3.1.4 upgrade.
    Posted Apr 10, 2014 09:07 PM
    I did have ap-specific configuration and it was configured incorrectly. Up and working now. Thanks for your help!
    Another mark for the user error column. :)
    -Chris
