RAP-3WN Configuration
  • 1.  RAP-3WN Configuration
    Posted Jun 06, 2014 04:01 AM
    dear all,
    please help me is there any way to configure DHCP server in RAP-3WN with out controller?
  • 2.  RE: RAP-3WN Configuration
    MVP GURU
    Posted Jun 06, 2014 06:11 AM
    Go to System and Enable Show Advanced Options
    And there is a tab with DHCP Settings (only for Client with Virtual Controller Assigned)
  • 3.  RE: RAP-3WN Configuration
    Posted Jun 06, 2014 11:04 AM
    The DHCP configuration is under the "More" tab if you need to specify specific pools.
  • 4.  RE: RAP-3WN Configuration
    Posted Jun 09, 2014 01:36 AM
    Dear alagoutte & Jamie E thanks for your kind response. If you have any scrreen shot then please share it.
    Regards
  • 5.  RE: RAP-3WN Configuration
    MVP GURU
    Posted Jun 10, 2014 04:41 AM
  • 6.  RE: RAP-3WN Configuration
    Posted Jun 11, 2014 03:28 AM
    Thanks dear:)
    all wtreless clients get my assigned ips. Now there is one more problem i conect switch with rap now the problem is all wired users unable to get ip which i define in dhcp kindly guide  me
  • 7.  RE: RAP-3WN Configuration
    MVP GURU
    Posted Jun 11, 2014 04:23 AM
    @asad rasool goraya wrote:
    Thanks dear:)
    The DHCP is only for Wireless client (like it is say in screenshot)
    for wired client, you need a another DHCP Server
  • 8.  RE: RAP-3WN Configuration
    Posted Jun 11, 2014 05:14 AM
    ok thanks dear
