RAP-3WN for Huawei 3276
  • 1.  RAP-3WN for Huawei 3276
    Posted Dec 12, 2014 06:02 AM
    Can anyone tell how to setup a RAP-3WN using a Huawei 3276 usb Modem? The controller for remote APs is in a dmz with OS 6.3.1.5. This is the first time i am doing it, please explain step by step.
    Thanks for the help!!!
  • 2.  RE: RAP-3WN for Huawei 3276
    Posted Dec 16, 2014 03:49 AM
    Immi,
    The Huawei 3276 has a minimum software releas of 6.4 for controller and 4.1 for Instant.
    Provisioning parameters:
    usb_type=huawei-cdc
    cellular_nw_preference=auto
    usb_dev=0x12d11506
    There are multiple versions of the E3276, not every type has been tested. The E3276-150 seems quite common and is reported to work.
    Herman
  • 3.  RE: RAP-3WN for Huawei 3276
    Posted Dec 17, 2014 02:16 AM
    hrobers,
    Thank you, will upgrade the image and try it out.
  • 4.  RE: RAP-3WN for Huawei 3276
    Posted Jan 14, 2015 05:00 AM
    I upgraded the image to 6.4 and the RAP is up in the Remote controller, but the USB doesnt seem to work. I provided the following details in the USB parameters.
    usb_type=huawei-cdc
    usb_dev=0x12d11506
    PPP username= Orange
    PPP Password = ********
    Do I need to specify other parameters as well:
    TTY Device data path
    TTY Device control path
    Initialization String
    Modeswitch
    if i have to give these, what would be the values for it.
    Thanks for your time and support...
    Immi
  • 5.  RE: RAP-3WN for Huawei 3276
    Posted Jan 14, 2015 05:39 AM
    Those parameters are optional, you should be able to leave them empty.
    If it does not work for you, please open a TAC case.
    Herman
