RAP-3WN instalation
  • 1.  RAP-3WN instalation
    Posted Jul 29, 2013 01:09 PM
    what is the procedure to connect RAP-3WN and aruba 650 controller through point to point connectevity ?
  • 2.  RE: RAP-3WN instalation
    Posted Jul 29, 2013 01:56 PM
    Do you mean through the dedicated point to point connection back to where the 650 is located ?
    What type of RAP are you using  ?
    If you have routing in place to reach the controller IP address and you allow UDP/4500 :
    - But all you need is create a ip pool for your RAPs
    - then add the mac address to the RAP whitelist
    You can also you this guide :
    http://community.arubanetworks.com/aruba/attachments/aruba/branch-wlan-and-remote-access/688/1/Mod12MBC-Remote%20AP-6.1-v1.0.pdf
    http://www.arubanetworks.com/wp-content/uploads/RAPVRD_version_8.pdf
  • 3.  RE: RAP-3WN instalation
    Posted Jul 30, 2013 12:58 PM
    Thanks Victor Fabian for your reply,
    Yes,point to point connection is back to the 650 controller,
    I used RAP-3WN model,it,s act as a remote AP.
    Yes,I have reach controller local side IP through point to point circuit,when I attached my laptop in directly to the router and when I connect to the RAP by default ssid(instant).
    IP pool is already created in the controller,device Mac id is also white listed in controller.
    In DSL infrastructure RAP directly converted to standalone to remote access point,and broadcast controller assigned ssid and IP pool but I face problem in point to point connectivity ,it,s converted but after conversion it,s not broadcast anything reboot simultaneously.
    Arnab Roy
    Network Support Enginner
  • 4.  RE: RAP-3WN instalation
    Posted Jul 30, 2013 01:49 PM
    Can you please enable the following ?
    logging level debugging security process crypto - To determine if it is getting denied
    show log security all | include <rapmacaddress>
    logging level debugging ap-debug - To see what's going on with the AP
    show log ap-debug all | include <rapmacaddress>
    And also do a show ap database long | include <rapmacaddress>
    Also make sure that the ssid is enabled  : show ap essid
    Make sure that the AP System profile has the IP address that you are using to point the RAP to the controller
    Can you please share the AP-Group ?
  • 5.  RE: RAP-3WN instalation
    Posted Jul 30, 2013 11:18 PM
    in where I enable this function RAP or Controller?
  • 6.  RE: RAP-3WN instalation
    Posted Jul 31, 2013 01:15 AM
    Arnab,
    What version of ArubaOS are you using?  You need 6.2 and above to convert a RAP3WN to a Remote AP.
  • 7.  RE: RAP-3WN instalation
    Posted Jul 31, 2013 03:06 AM
    I used version 6.1.3.0-3.1.0 in RAP.
  • 8.  RE: RAP-3WN instalation
    Posted Jul 31, 2013 03:14 AM
    No.  What version on the Aruba Controller?
  • 9.  RE: RAP-3WN instalation
    Posted Jul 31, 2013 03:22 AM
    Name:Aruba Operating System Software.
    Model:Aruba650
    Version:6.2.1.2
  • 10.  RE: RAP-3WN instalation
    Posted Jul 31, 2013 03:34 AM
    Okay,
    Paste in these commands into the controller:
    config t
    logging level debugging security subcat ike
    logging level debugging security process aaa
    logging level debugging security process authmgr
    logging level debugging security subcat l2tp
    logging level debugging security subcat vpn
     When the RAP boots up, type "show log security 100" and send us that output, so we can see what is going on.
  • 11.  RE: RAP-3WN instalation
    Posted Jul 31, 2013 06:21 AM
    Here's the snapshot of where do you add the LMS ip address or IP address of the controller that you are using to convert the IAP to a RAP
  • 12.  RE: RAP-3WN instalation
    Posted Jul 31, 2013 08:59 AM
    Hi
    I think, you should try to convert this AP into Campus mode before Remote mode using the same VLAN between Controller and the AP (AP must be in the Campus whitelist). When it's up you can provision it as a remote AP.
