Aruba Apps
last person joined: 9 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
RAP-3WN WLAN light is not up after conversion
  • 1.  RAP-3WN WLAN light is not up after conversion
    Posted Mar 10, 2021 10:47 AM
    ​I have converted 3 RAP-3WN units, 1 unit is working fine, however, the other 2 unit are facing the same issue - the WLAN light is not up ( from Aruba controller can see WLAN=0, can someone help on this?
    Many thanks in advance!
    Chuan
    Chuan Wang
  • 2.  RE: RAP-3WN WLAN light is not up after conversion
    Posted Mar 11, 2021 08:52 AM
    What type of conversion did you attempt? Did you convert them as AP or RAP to a controller?
    If so, do you see the APs appear on the controller?
    What shows the show ap active and show ap database?
    Show log all on the controller, in general, should give indications as well.
    If you don't feel comfortable looking through the logs, your Aruba partner or Aruba TAC support should be able to assist you.
  • 3.  RE: RAP-3WN WLAN light is not up after conversion
    Posted Mar 11, 2021 09:04 PM
    Hi Herman,
    Thanks! The issue has been fixed and root cause was my partner add 3 RAPs with ONE same user name which caused the issue.
    The 2 RAPs were up and running well (WLAN is lighted up) after we re-added them with 2 different user name.
    Thanks & Regards
    Chuan​
    Chuan Wang
