RAP-3WNP can't ping anywhere
  • 1.  RAP-3WNP can't ping anywhere
    Posted Feb 22, 2018 03:49 AM
    HW INFO:
    -RAP-3WNP
    -Cisco Switch 3750
    STEPS TAKEN:
    1. create 2 SSIDs (EMPLOYEE and GUEST)
    PROBLEMS:
    1. RAP can't ping anywhere
    3750 can't ping RAP
    but PC connected to EMPLOYEE SSID can go anywhere
    because pc can't ping RAP. I can't manage it
    1. why "show running-config" didn't show its ip but show ip only in "sh ip int"
    2. is this problem caused by config in 3750 native vlan?
    NOTE:
    -if I set 3750 port f2/0/35 native vlan to 40 (RAP ip is 10.0.40.129). I can ping RAP but pc can't get DHCP
    -if I set 3750 port f2/0/35 native vlan to 1 (RAP ip is 10.0.40.129). I can't ping RAP but pc can get DHCP
    tq
    RAP-3WNP:
    # sh ip int
    Interface IP Address / IP Netmask Admin Protocol
    br0 10.0.40.129 / 255.255.255.0 up up
    # show run
    version 6.4.4.0-4.2.4
    virtual-controller-country US
    virtual-controller-key f787bd610138808ad3f09ba2cf057551ec1731946730cb98a1
    name instant-82:74:1D
    terminal-access
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap 00:0b:86:82:74:1d
    arm
    wide-bands 5ghz
    80mhz-support
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode default-access
    client-aware
    scanning
    ip dhcp pool
    domain-name ngtrain.com
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    user guest1 3b1ddfd86a472fa134882c86677673daa13927dd41f29377 portal
    mgmt-user admin 14142b96cf0988b96b46526cf0afda2a
    wlan access-rule GUEST
    index 0
    rule any any match any any any permit
    wlan access-rule default_wired_port_profile
    index 1
    wlan access-rule wired-instant
    index 2
    rule masterip 0.0.0.0 match tcp 80 80 permit
    rule masterip 0.0.0.0 match tcp 4343 4343 permit
    rule any any match udp 67 68 permit
    rule any any match udp 53 53 permit
    wlan access-rule EMPLOYEE
    index 3
    wlan ssid-profile GUEST
    enable
    index 0
    type guest
    essid GUEST
    opmode opensystem
    max-authentication-failures 0
    vlan 60
    auth-server InternalServer
    rf-band all
    captive-portal internal
    dtim-period 1
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    wlan ssid-profile EMPLOYEE
    enable
    index 1
    type employee
    essid EMPLOYEE
    wpa-passphrase db13aa3033cfeb4540b145966b7f6a9bc2aed79d1fa409ee
    opmode wpa2-psk-aes
    vlan 40
    rf-band all
    captive-portal disable
    dtim-period 1
    auth-survivability cache-time-out 24
    wlan captive-portal
    background-color 13421772
    banner-color 16750848
    banner-text "Welcome to Guest Network"
    terms-of-use "This network is not secure, and use is at your own risk"
    use-policy "Please read terms and conditions before using Guest Network"
    authenticated
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    auto-whitelist-disable
    https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
    wireless-containment none
    wired-port-profile wired-instant
    switchport-mode access
    allowed-vlan all
    native-vlan guest
    no shutdown
    access-rule-name wired-instant
    speed auto
    duplex auto
    no poe
    type guest
    no dot1x
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    failover-internet-pkt-lost-cnt 10
    failover-internet-pkt-send-freq 30
    failover-vpn-timeout 180
    airgroup
    disable
    airgroupservice airplay
    disable
    description AirPlay
    airgroupservice airprint
    disable
    description AirPrint
    3750:
    version 12.2
    system mtu routing 1500
    vtp domain ngtrain
    vtp mode transparent
    ip routing
    ip domain-name ngtrain.com
    ip name-server 9.9.9.9
    ip dhcp excluded-address 10.0.40.1 10.0.40.100
    ip dhcp excluded-address 10.0.50.1 10.0.50.100
    ip dhcp excluded-address 10.0.60.1 10.0.60.100
    ip dhcp excluded-address 10.0.40.201 10.0.40.254
    ip dhcp excluded-address 10.0.50.201 10.0.50.254
    ip dhcp excluded-address 10.0.60.201 10.0.60.254
    ip dhcp pool DHCPVLAN50
       network 10.0.50.0 255.255.255.0
       dns-server 10.0.30.11
       default-router 10.0.50.1
    ip dhcp pool DHCPVLAN60
       network 10.0.60.0 255.255.255.0
       default-router 10.0.60.1
    ip dhcp pool DHCPVLAN40
       network 10.0.40.0 255.255.255.0
       default-router 10.0.40.1
    archive
    path flash:/CONFIG
    spanning-tree mode pvst
    vlan 10
    name WAN
    vlan 20
    name DMZ
    vlan 30
    name SERVER
    vlan 40
    name USER
    vlan 50
    name VOICE
    vlan 60
    name GUEST
    vlan 100
    name MGMT
    ip ssh version 2
    interface Port-channel1
    switchport trunk encapsulation dot1q
    switchport trunk allowed vlan 1,10,20,30,40,50,60,100
    switchport mode trunk
    switchport nonegotiate
    interface Port-channel2
    switchport trunk native vlan 100
    switchport trunk allowed vlan 1,40,50,60,100
    interface FastEthernet2/0/35
    description AP
    switchport trunk allowed vlan 40,50,60
    interface FastEthernet2/0/36
    description AP
    interface FastEthernet2/0/37
    description 3400
    channel-protocol lacp
    channel-group 2 mode active
    interface FastEthernet2/0/38
    description 3400
    interface Vlan1
    ip address 10.0.1.1 255.255.255.0
    interface Vlan10
    description WAN
    ip address 10.0.10.211 255.255.255.0
    interface Vlan20
    description DMZ
    ip address 10.0.20.1 255.255.255.0
    interface Vlan30
    description SERVER
    ip address 10.0.30.1 255.255.255.0
    interface Vlan40
    description USER
    ip address 10.0.40.1 255.255.255.0
    interface Vlan50
    description VOICE
    ip address 10.0.50.1 255.255.255.0
    interface Vlan60
    description GUEST
    ip address 10.0.60.1 255.255.255.0
    interface Vlan100
    description MGMT
    ip address 10.0.100.1 255.255.255.0
