Rap-5 showing up as Wired AP
  • 1.  Rap-5 showing up as Wired AP
    Posted Jun 07, 2012 10:13 AM
    Hello all -
    We have 3 RAP-5's and what I didn't notice when I configured them and shipped them out is that they show up in the controller as Wired AP's. So I have a couple of questions:
    1. is that normal? (I have Rap-5wn's wgs that don't...) so wondered if that w ment wireless...
    2. do I need to create a wired profile for them and if so, what issues am I going to see - looks like I can pick the same profile that the wireless aps use - just not sure if there is anything else
    3. any other "hidden" issues that we may encounter?
    thank you
    Lirria
  • 2.  RE: Rap-5 showing up as Wired AP
    Posted Jun 07, 2012 12:02 PM
    Lirra,
    These are true RAP-5s, not RAP-5WNs? If so they do not have wireless access points built in, that's why they show up that way. You should be able to use the same wired profile as your RAP-5WNs.
    -awl
  • 3.  RE: Rap-5 showing up as Wired AP
    Posted Jun 07, 2012 12:12 PM
    hmm - so does that mean it's not actually an AP, but a wired only piece of hardware?
    My bad for not catching that when it was ordered.
    Lirra
  • 4.  RE: Rap-5 showing up as Wired AP
    Posted Jun 07, 2012 12:26 PM
    Yes, RAP-5 is wired only for places where you need a wired L2 extension but not wireless. The RAP-5WN is the wireless variant.
    -awl
  • 5.  RE: Rap-5 showing up as Wired AP
    Posted Jun 07, 2012 12:35 PM
    *sigh*
    Well crap - ok - thank you - that does explain it - I'll have to take a look at the offices and see if that is going to work or if we need to recall it back and get something different.
    I hate it when I make that kind of a mistake.
    Lirria
