RAP-5WN and RAP2-WG with ArubaOS 6.4
  • 1.  RAP-5WN and RAP2-WG with ArubaOS 6.4
    Posted Jan 14, 2016 02:55 PM
    Will RAP-5WN and RAP2-WG APs not work if I upgrade to AOS 6.4? I want to purchase AP205s, but they will only run on AOS 6.4. Don't want to upgrade to 6.4 for the purpose of getting AP205 if that will kill my RAPs from fucntioning.
    Tony Maruqes
  • 2.  RE: RAP-5WN and RAP2-WG with ArubaOS 6.4
    Posted Jan 14, 2016 02:56 PM
    The last supported code for the RAP-5 is 6.3. If you upgrade to 6.4, those will not boot.
  • 3.  RE: RAP-5WN and RAP2-WG with ArubaOS 6.4
    Posted Jan 14, 2016 03:25 PM
    Hi Tim,
    Thanks for the confirmation. I would safely assume that AP205 won't boot on 6.4 code correct?
    Tony Marques
  • 4.  RE: RAP-5WN and RAP2-WG with ArubaOS 6.4
    Posted Jan 14, 2016 03:28 PM
    The 205 will not boot with a code older than 6.4.1
