RAP and PCI compliance
  • 1.  RAP and PCI compliance
    Posted Dec 03, 2012 06:00 PM
    I am wondering if anyone can give me some information on the RAP's and it's ablility to be PCI compliant in the following configuation.
    I will have a DSL/3g/4g connection into a RAP5 the RAP will provide normal Wireless monitoring and connectivity for NON CDE data. 1 port on the RAP5 will be set to tunel all traffic back to datacenter and will have PCI data on it.
    See the attached PDF for a visual of what i am looking at.
    Attachment(s)
    pdf
    RAP Question.pdf   209 KB 1 version
  • 2.  RE: RAP and PCI compliance
    Posted Jun 08, 2014 04:47 PM
    Statefull firewall inspection (check)
    Segmentaiton of CDE and non-CDE data (check)
    WPA/WPA2 encryption on CDE network (check I assume??)
    Assuming you're also doing rogue detection you should be compliant.
    This question was posted a while ago, so I assume you figured it out.  Can you reply back with your experience in making sure your network was PCI compliant?
