RAP and Split-tunnel problem
  • 1.  RAP and Split-tunnel problem
    Posted May 02, 2018 02:46 PM
    Hello everyone,
    We have this situation:
    2x Controllers 7030 ArubaOS 8.2.1.0
    17x Campus AP
    1x RAP for branch office
    Clearpass 6.7.1
    VLAN ID 135 - Controller is the gateway and there is no traffic blocked in the network.
    When we configure the SSID to tunnel-mode the client can resolve names, is redirected to portal and login without problems.
    When we change the SSID to split-tunnel, the client can ping DNS servers but can't resolve names, and consequently can't redirected to cppm guest portal and login.
    Any ideia?
  • 2.  RE: RAP and Split-tunnel problem
    Posted May 02, 2018 02:50 PM
    What is your split-tunnel ACL?
  • 3.  RE: RAP and Split-tunnel problem
    Posted May 02, 2018 02:55 PM
    There is. The alias pt-guest is the cppm IP Address
    (CTR-AP-LC-01) [mynode] #show rights pt-guest-guest-logon
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'pt-guest-guest-logon'
    Up BW:No Limit Down BW:No Limit
    L2TP Pool = default-l2tp-pool
    PPTP Pool = default-pptp-pool
    Number of users referencing it = 0
    Periodic reauthentication: Disabled
    DPI Classification: Enabled
    Youtube education: Disabled
    Web Content Classification: Enabled
    IP-Classification Enforcement: Enabled
    ACL Number = 110/0
    Openflow: Enabled
    Max Sessions = 65535
    Check CP Profile for Accounting = TRUE
    Captive Portal profile = PT-GUEST
    Application Exception List
    Name Type
    Application BW-Contract List
    Name Type BW Contract Id Direction
    access-list List
    Position Name Type Location
    1 global-sacl session
    2 apprf-pt-guest-guest-logon-sacl session
    3 pt-guest-guest-logon session
    4 logon-control session
    5 captiveportal session
    global-sacl
    Priority Source Destination Service Application Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan IPv4/6 Contract
    1 any pt-guest svc-http permit Low 4
    2 any pt-guest svc-https permit Low 4
    logon-control
    1 user any udp 68 deny Low 4
    2 any any svc-icmp permit Low 4
    3 any any svc-dns permit Low 4
    4 any any svc-dhcp permit Low 4
    5 any any svc-natt permit Low 4
    6 any 169.254.0.0 255.255.0.0 any deny Low 4
    7 any 240.0.0.0 240.0.0.0 any deny Low 4
    captiveportal
    1 user controller svc-https dst-nat 8081 Low 4
    2 user any svc-http dst-nat 8080 Low 4
    3 user any svc-https dst-nat 8081 Low 4
    4 user any svc-http-proxy1 dst-nat 8088 Low 4
    5 user any svc-http-proxy2 dst-nat 8088 Low 4
    6 user any svc-http-proxy3 dst-nat 8088 Low 4
    Expired Policies (due to time constraints) = 0
  • 4.  RE: RAP and Split-tunnel problem
    Posted May 02, 2018 04:08 PM
    From the looks of it, DNS should work.
    You can type "show datapath session ap-name <name of rap>" when you are trying to reach your DNS server to see what is happening to your sessions.
  • 5.  RE: RAP and Split-tunnel problem
    Posted May 02, 2018 04:24 PM
  • 6.  RE: RAP and Split-tunnel problem
    Posted May 02, 2018 04:28 PM
  • 7.  RE: RAP and Split-tunnel problem
    Posted May 02, 2018 04:30 PM
  • 8.  RE: RAP and Split-tunnel problem
    Posted May 02, 2018 06:16 PM
  • 9.  RE: RAP and Split-tunnel problem
    Posted May 02, 2018 06:19 PM
    I also filtered my laptop's IP 10.199.5.8. The DNS Servers are 10.198.50.10 and 10.198.50.6. I've already tried to use another laptop, so, we can discard this. Follow attached.
    Attachment(s)
    txt
    show datapath session.txt   6 KB 1 version
  • 10.  RE: RAP and Split-tunnel problem
    Posted May 02, 2018 09:13 PM
    There are two columns, tAge and Packets that are missing from your output.
    Are you sure that access point is configured as a remote AP?
  • 11.  RE: RAP and Split-tunnel problem
    Posted May 03, 2018 09:07 AM
    Well... it's showing in the GUI as RAP.
    I've already an open case, but the TAC can't find any errors in the configuration. And we don't know what to do now.
  • 12.  RE: RAP and Split-tunnel problem
    Posted May 03, 2018 09:13 AM
    TAC should open a bug and attempt to replicate this.
  • 13.  RE: RAP and Split-tunnel problem
    Posted May 03, 2018 12:51 PM
    Hi
    I performed the command again and now is showing this outputs, see attachments. I also executed the show user ip <IP>.
    Attachment(s)
