  • 1.  RAP + AP
    Posted Apr 23, 2013 06:54 AM
    Here is the case.
    I have customers who are alreday equipped with Mikrotik devices. As I don't want to change them all because of the costs, the question is :
    Is it possible to configure the Mikrotik as an AP device and connect it to a RAP-IAP (with wired connection) so I can use my CP Guest Self-Registration ? Did anyone already try something like this ?
    Dimitri
  • 2.  RE: RAP + AP
    Posted Apr 23, 2013 11:31 AM
    I have find the solution. Simply connect my Mikrotik AP to the eth1 port of my RAP and configured the wired eth1. Also modify a service in ClearPass Policy Manager.
    Dimitri
