RAP APs
This thread has been viewed 19 times
  • 1.  RAP APs
    Posted Jan 21, 2022 06:22 PM
    Dears,
     i have  rap access point with public IP address and  configure in controller vpn pool  i tried to terminated to MC controller from  (cluster) but not showing in controller but when configure access point get image from controller
    how can solve this issue
    mohamed gamal
  • 2.  RE: RAP APs
    Posted Jan 21, 2022 06:54 PM
    Did you configure a RAP Public ip address for all controllers in the cluster profile for that cluster?  Does your firewall have a static NAT on your firewall mapping from public to private ip addresses?  Are you allowing UPD 4500?
    Have you seen the Remote AP solution guide here?  https://support.hpe.com/hpesc/public/docDisplay?docId=a00097853en_us
  • 3.  RE: RAP APs
    Posted Jan 21, 2022 07:38 PM
    in first i configure a public ip for vrrp ip to cluster then configure for one ip from cluster
    yes and allowedupd 4500 and configure nating in fireall to public ip
    NAT-T (udp/4500)
    TFTP (UDP/69)
    mohamed gamal
  • 4.  RE: RAP APs
    Posted Jan 21, 2022 09:00 PM
    You cannot do a NAT to a VRRP.
