last person joined: 3 hours ago
RAP - Bridge mode with network DHCP
  • 1.  RAP - Bridge mode with network DHCP
    Posted Aug 15, 2019 05:20 PM
    Hey guys, I'm trying to get a RAP working with a PSK SSID running bridge mode, using my network DHCP. It is working fine with Tunnel mode. AOS 8.5.0.1
    When I have my SSID set to bridge mode and I use a VLAN ID that matches my Native VLAN, I get an IP address but all my traffic is blocked.
    For my rules, I am using the following:
    any any svc-dhcp permit
    local-subnet local-subnet permit (including default gw IP)
    any any route source nat (as indicated by config guides/VRD).
    I am unable to ping even the default gateway. Any ideas what I could be missing? Also, everywhere I checked indicates to use the final source nat rule, but why do I need it if I am using a local network address? Seems like the last rule should just be any any permit.
    I can see the user on the controller (show user-table) and see the correct role and bridge mode.
    The uplink (ethernet 0) port does not have wired ap on, but is set to trusted. Should I enable wired ap?
    Thanks!
    RK
  • 2.  RE: RAP - Bridge mode with network DHCP
    Posted Aug 15, 2019 06:15 PM
    You should just be able to use "any any any permit" and have all the traffic pass
    You do not need "src-nat" if the VLAN exists on the LAN.  You would only need src-nat if the VLAN only exists within the AP and you are source-natting traffic out of the ip address of the AP.
  • 3.  RE: RAP - Bridge mode with network DHCP
    Posted Aug 15, 2019 07:59 PM
    Thanks for the quick reply!
    Tried using any any permit, no luck. Everything should be untagged (using vlan 1), so I’m not sure what is going on. Might have to wireshark this. The fact that I do get an IP but nothing else is what is driving me crazy...
    Anything I could be missing? Don’t think I need to change the ethernet port profile...
  • 4.  RE: RAP - Bridge mode with network DHCP
    Posted Aug 15, 2019 10:25 PM
    You should type "show datapath ap-name <name of AP>" to see if traffic is being denied.
  • 5.  RE: RAP - Bridge mode with network DHCP
    Posted Aug 16, 2019 08:50 AM
    Ok. Checked the datapath session and traffic is being denied, but I can't figure out why! Ideas?
    CTL-ARUBA-2) #show datapath session ap-name ap2516
           Q - Real-Time Quality analysis
           u - Upstream Real-Time Quality analysis
           E - Media Deep Inspect, G - media signal
           r - Route Nexthop, h - High Value
           A - Application Firewall Inspect
           B - Permanent, O - Openflow
           L - Log
    AP Flags: 1 - Class 1, 2 - Class 2, 3 - Class 3, w - In hardware
    Source IP or MAC  Destination IP  Prot SPort DPort Cntr     Prio ToS Age Destination TAge Packets    Bytes      Flags           AP Flags        CPU ID
    (CTL-ARUBA-2) #show datapath session ap-name ap2516 | include .50
    172.20.0.50       8.8.8.8         17   60655 53    0        0    0   0   dev19       2400 --         --         FDYCA                           0
    172.20.0.62       201.54.48.50    17   51757 4500  0        0    0   0   local       81f  --         --         FC                              0
    172.20.0.50       8.8.8.8         17   52649 53    0        0    0   0   dev19       700  --         --         FDYCA                           0
    172.20.0.50       171.20.0.254    1    33    2048  0        0    0   0   dev19       1200 --         --         FDYCA                           0
    172.20.0.50       171.20.0.254    1    32    2048  0        0    0   0   dev19       1700 --         --         FDYCA                           0
    172.20.0.50       171.20.0.254    1    35    2048  0        0    0   0   dev19       800  --         --         FDYCA                           0
    172.20.0.50       171.20.0.254    1    34    2048  0        0    0   0   dev19       d00  --         --         FDYCA                           0
    172.20.0.50       171.20.0.254    1    36    2048  0        0    0   0   dev19       300  --         --         FDYCA                           0
    201.54.48.50      172.20.0.62     17   4500  51757 0        0    0   0   local       91f  --         --         F                               0
    172.20.0.50       192.168.96.1    1    0     2048  0        0    0   0   dev19       4400 --         --         FDYCA                           0
    (CTL-ARUBA-2) #show user-table | include 97:05
    fe80::1c22:ade1:f018:eb49  14:99:e2:bf:97:05                             local-inicial    00:00:15        AP2516   Associated(Remote)  SF-Local/9c:8c:d8:4d:0b:53/a-HT         AAA-Local               bridge        WIRELESS
    (CTL-ARUBA-2) #show rights local-inicial
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'local-inicial'
    Up BW:No Limit   Down BW:No Limit
    L2TP Pool = default-l2tp-pool
    PPTP Pool = default-pptp-pool
    Number of users referencing it = 2
    Periodic reauthentication: Disabled
    DPI Classification: Enabled
    Youtube education: Disabled
    Web Content Classification: Enabled
    IP-Classification Enforcement: Enabled
    ACL Number = 217/0
    Openflow: Enabled
    Max Sessions = 65535
    Check CP Profile for Accounting = TRUE
    Application Exception List
    Name  Type
    Application BW-Contract List
    Name  Type  BW Contract  Id  Direction
    access-list List
    Position  Name                      Type     Location
    1         global-sacl               session
    2         apprf-local-inicial-sacl  session
    3         local-inicial             session
    global-sacl
    Priority  Source  Destination  Service  Application  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  IPv4/6  Contract
    local-inicial
    1         any                       any                       svc-dhcp               permit                                  Low                                                      4
    2         172.20.0.0 255.255.255.0  172.20.0.0 255.255.255.0  any                    permit                                  Low                                                      4
    3         user                      any                       any                    route src-nat                           Low                                                      4
  • 6.  RE: RAP - Bridge mode with network DHCP
    Posted Aug 16, 2019 08:55 AM
    EDIT  Please just use permit, instead of route src-nat.  That might not be your issue, but you should just allow all.  See if you can ping devices in the subnet 172.20.0.0 255.255.255.0 since that is being allowed.
    Okay, I see from the datapath session table, you are trying to ping and it is not working.  Check to see if you have an ap-uplink-acl configured in your ap system profile:
    If you do, make sure that ap-uplink-acl is configured to "allowall"
  • 7.  RE: RAP - Bridge mode with network DHCP
    Posted Aug 16, 2019 11:08 AM
    Ok, found the issue! We noticed that the IPv4 address was not being added to the firewall table, only IPv6. Turns out the validuseracl was previously editted to allow only the corp subnet ranges, so what was actually happening is that the user was not being included into the tables at all! So all his traffic was being blocked.
    anyways, thanks for all the help!
    sincerely,
    RK
