  • 1.  RAP config
    Posted Mar 25, 2014 05:42 PM
    Attempting to provision a rap remote.  Currently on the network, all internal APs are configured as RAPs.  This is the first RAP that will be pointing to the public IP.  when trying to provision from one machine, it gets stuck at "Please wait", on the other, it moves to setting up VPN, then pops up with below:
    Target : 00:0b:86:9f:8e:d3
    show vpn status
    profile name:default
    current using tunnel :unselected tunnel
    ipsec is preempt status :disable
    ipsec is fast failover status :disable
    ipsec hold on period :600
    ipsec tunnel monitor frequency (seconds/packet) :10
    ipsec tunnel monitor timeout by lost packet cnt :2
    ipsec primary tunnel crypto type :Cert
    ipsec primary tunnel peer address :x.x.x.x
    ipsec primary tunnel peer tunnel ip :0.0.0.0
    ipsec primary tunnel ap tunnel ip :0.0.0.0
    ipsec primary tunnel current sm status :Retrying
    ipsec primary tunnel tunnel status :Down
    ipsec primary tunnel tunnel retry times :34
    ipsec primary tunnel tunnel uptime :0
    ipsec backup tunnel crypto type :Cert
    ipsec backup tunnel peer address :N/A
    ipsec backup tunnel peer tunnel ip :N/A
    ipsec backup tunnel ap tunnel ip :N/A
    ipsec backup tunnel current sm status :Init
    ipsec backup tunnel tunnel status :Down
    ipsec backup tunnel tunnel retry times :0
    ipsec backup tunnel tunnel uptime :0
    end of show vpn status
    show upgrade info
    Image Upgrade Progress
    Mac IP Adress AP Class Status Image Info Error Detail
    00:0b:86:9f:8e:d3 192.168.155.204 Orion image-ok image file none
    end of show upgrade info
    show log upgrade
    ----------Download log start----------
    download log not available
    ----------Download log end------------
    Download status: incomplete
    ----------Upgrade log start----------
    upgrade log not available
    ----------Upgrade log end------------
    Upgrade status: upgrade status not available
    end of show log upgrade
    show log rapper
    Mar 25, 20:35:31: get_ike_version: Use IKE Version 2
    Mar 25, 20:35:31: papi_init papifd:9 ack:10
    IKE_EXAMPLE: Starting up IKE server
    setup_tunnel
    Mar 25, 20:35:31: IKE_init: ethmacstr = 00:0B:86:9F:8E:D3
    Initialized Timers
    IKE_init: completed after (0.0)(pid:31020) time:2014-03-25 20:35:31
    seconds.
    Mar 25, 20:35:31: RAP using default certificates
    Mar 25, 20:35:31: Before getting Certs
    Mar 25, 20:35:31: TPM enabled
    Mar 25, 20:35:31: CA_MGMT_EXAMPLE_computeHostKeys init cert-len 0
    Mar 25, 20:35:31: Factory Device Cert is /tmp/deviceCerts/certifiedKeyCert.der
    Mar 25, 20:35:31: Reading DER Device Cert file /tmp/deviceCerts/certifiedKeyCert.der
    Mar 25, 20:35:31: DER Device Cert file len:1767
    Mar 25, 20:35:31: Intermediate Cert index:0 is /tmp/deviceCerts/certifiedKeyCaCert.der
    Mar 25, 20:35:31: Reading DER Intermediate Cert file
    Mar 25, 20:35:31: DER Intermediate Cert file len:1457
    Mar 25, 20:35:31: Intermediate Cert index:1 is /tmp/deviceCerts/caChainCert1.der
    Mar 25, 20:35:31: DER Intermediate Cert file len:1580
    Mar 25, 20:35:31: Decode PEM Key length :0
    Mar 25, 20:35:31: testHostKeys : status 0
    Mar 25, 20:35:31: testHostKeys : free temp Certificate status 0
    Mar 25, 20:35:31: CA_MGMT_EXAMPLE_computeHostKeys after testHostKeys cert-len 1767
    Mar 25, 20:35:31: CA Cert index:0 is /tmp/deviceCerts/OpensslOldCA_RootCert.der
    Mar 25, 20:35:31: Reading DER CA Cert file
    Mar 25, 20:35:31: DER CA Cert file len:1416
    Mar 25, 20:35:31: CA Cert index:1 is /tmp/deviceCerts/MSCAV1_RootCert.der
    Mar 25, 20:35:31: DER CA Cert file len:1009
    Mar 25, 20:35:31: Got 2 Trusted Certs
    Mar 25, 20:35:31: After getFieldTrustedCerts ret:-1
    Mar 25, 20:35:31: Got 0 Field Trusted Certs
    Mar 25, 20:35:31: CSS CA Cert is /tmp/deviceCerts/CSS_CA_RootCert.der
    Mar 25, 20:35:31: Error in reading DER CA Cert:/tmp/deviceCerts/CSS_CA_RootCert.der, Ignore It
    Mar 25, 20:35:31: CA Cert status : 0
    Before IKE_initServer
    Mar 25, 20:35:31: IKE_initServer: Cert length 1767
    IKE_initServer: Host Certificate is set (RSA-SIG)
    {CN=BF0067549::00:0b:86:9f:8e:d3}
    Mar 25, 20:35:31: IKE_EXAMPLE_addServer port:0 natt:0
    Mar 25, 20:35:31: srcdev_name = br0 ip c0a89bcc
    Mar 25, 20:35:31: IKE_EXAMPLE_addUdpSkt: Using SocketIndex:0
    IKE_EXAMPLE: Socket created on 192.168.155.204[49220]
    Mar 25, 20:35:31: IKE_EXAMPLE_addServer:1413 socket descriptor is 0 port number 49220 for server instance 0 at 0th index
    Mar 25, 20:35:31: IKE_EXAMPLE_addUdpSkt: Using SocketIndex:1
    IKE_EXAMPLE: Socket created on 192.168.155.204[49221]
    Mar 25, 20:35:31: IKE_EXAMPLE_addServer:1460 socket descriptor is 1 port number 49221 for server instance 0 at 1st index
    Mar 25, 20:35:31: IKE_EXAMPLE_addDefaultServers status:0
    SA_INIT dest=x.x.x.x
    Mar 25, 20:35:31: Initialize IKE SA
    Mar 25, 20:35:31: IKE_CUSTOM_getVersion(peerAddr:d1b76270): ikeVersion:2
    Timer ID: 1 Initialized
    Mar 25, 20:35:31: IKE2_newSa(peerAddr:d1b76270): IKE_SA-lifetime:28000
    I -->
    Mar 25, 20:35:31: OutSa(v2-peerAddr:0 pxSa->dwPeerAddr:d1b76270): Entered
    Mar 25, 20:35:31: OutTfm_I(v2-peerAddr:d1b76270): Entered
    ENCR_AES 256-BITS
    PRF_HMAC_SHA1
    AUTH_HMAC_SHA1_96
    DH_2
    NAT_D (us): c5 81 0c 68 c9 34 1a ff 4c ac ad 80 08 bb 9f 8f
    68 0d 00 d0
    NAT_D (peer): cb 7a 6c b6 8b c8 e4 11 d5 73 ef fa 08 a6 50 d5
    df bd e8 f6
    spi={cf5bf96669e6711c 0000000000000000} np=SA
    exchange=IKE_SA_INIT msgid=0 len=376
    #SEND 380 bytes to x.x.x.x[4500] (0.0)(pid:31020) time:2014-03-25 20:35:31
    Mar 25, 20:35:31: IKE_SAMPLE_ikeXchgSend Successfully setsockopt UDP_ENCAP port 49221
    IKE_EXAMPLE: IKE_keyConnect() started, id = 0xMar 25, 20:35:31: IKE_EXAMPLE: IKE_keyConnect() started, id = 0x on device br0
    dae19b1a...
    Mar 25, 20:35:31: papi:15200
    #SEND 380 bytes to x.x.x.x[4500] (5.0)(pid:31020) time:2014-03-25 20:35:36
    #SEND 380 bytes to x.x.x.x[4500] (10.0)(pid:31020) time:2014-03-25 20:35:41
    #SEND 380 bytes to x.x.x.x[4500] (15.0)(pid:31020) time:2014-03-25 20:35:46
    Mar 25, 20:35:51: IKE_checkExpSa rekey notfinished timeout 20000 sec
    Mar 25, 20:35:51: IKE_SAMPLE_ikeStatHdlr(CHILD_SA): dwPeerAddr:d1b76270 index:0 mPeerType:0
    Mar 25, 20:35:51: IKE SA failed reason = ERR_IKE_TIMEOUT, errorcode = -8949 ikeVer 2
    Mar 25, 20:35:51: send_sapd_error: InnerIP:0 error:43 debug_error:-8949
    Mar 25, 20:35:51: send_sapd_error: error:43 debug_error:-8949
    Mar 25, 20:35:51: IKE_SAMPLE_ikeStatHdlr(SA): dwPeerAddr:d1b76270 index:0 mPeerType:0
    Mar 25, 20:35:51: IKE_SA [v2 I] (id=0xdae19b1a) flags 0x41000005 failed reason = ERR_IKE_TIMEOUT, errorcode = -8949
    Mar 25, 20:35:51: IKE_SAMPLE_ikeStatHdlr(IST_FAIL): g_ikeversion:2
    Timer ID: 1 Deleted
    rapperSendStatusCB
    end of show log rapper
  • 2.  RE: RAP config
    Posted Mar 25, 2014 06:10 PM
    Figured this one out.  Looks like security guys took a bit longer than they said opening up port 4500.
